586,604 active members*
3,419 visitors online*
    Mar 2008
    Exclamation FANUC OM CONTROL PROGRAMS
    I am looking for programs,canned cycles...etc That are written for a Fanuc OM control.I really need a pocket milling program.Any and all help would be greatly appreciated! THANK YOU...
    992
    can you be more percific what you want?
    The best way to learn is trial error.
    Mar 2008
    I am looking for a pocket program to mill a 1 inch diameter hole 1 inch deep into a piece of steel. I am not familiar with this control and when I write the program the way I am used to it just errors out. it is a fanuc om control on a daewoo vmc. I am just looking for a few programs that are proven on the same type of control to see what I am missing.
    Feb 2008
    19
    Quote Originally Posted by jvmjr1973 View Post
    :4001 (HELICAL)
    G21 G40 G80 G90
    G0 G54 G90 X0 Y0 S2000 M3
    G43 Z5.H3
    #100 =-20.(FINISH DEPTH)
    #101 =10.(RADIUS OF CUTTER)
    #102 =30.(HOLE DIAMETER)
    #103 =150 (FEEDRATE)
    #104 =5.(PECKING DEPTH)
    #105 =0 (START DEPTH)
    #106 =#104
    #107 =ABS[#100 ]/#104 (NUMBER OF PASSES)
    #107 =ROUND[#107 ]
    #102 =#102/2.
    #102 =#102-#101
    G1 Z#105 F500
    G1 X#102
    #1 =1
    WHILE[#1 LE#107 ]DO1
    G3 I-#102 Z[#105-[#104*#1 ]]
    #1 =#1+1
    END1
    G3 I-#102
    G0 X0 Y0
    N10 Z10.
    G91 G28 Z0
    M30
    This is in metric but will work on imperial, hope it helps
    Apr 2008
    Smile Hello!
    I 'm fresher,nice to meet you
  1. Heidenhain control / programs
    By Rogue in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-30-2015, 07:01 AM
  2. Problem loading programs into DX32 control
    By D.Blair in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2008, 03:32 AM
  3. can't load programs to Fanuc
    By rookieee in forum DNC Problems and Solutions
    Last Post: 02-23-2008, 01:23 AM
  4. Sending programs FROM Fanuc 0-PC
    By scottsr60 in forum Fanuc
    Last Post: 01-02-2007, 02:07 PM
  5. lock programs with fanuc 16/18 control
    By Heavy D in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2006, 12:09 AM
