Also the driver will have a minimum voltage that will be at lest twice the rated voltage of the motor.
Below this voltage and the driver will not start.
Originally Posted by
stirling
So... The torque curves for my motor show torque starting at 500fsps to be around the 2.5Nm (354 in oz) mark. Given I'll be using a quality microstepping driver can I assume the following?
There is absolutely no point in doing "the norm" of using a Voltage several times the rated voltage. Because I'm never going to get to the speed where torque drops inversly with current.
i.e. I should use the rated voltage of my motor.
This sounds too easy (for once)
Comments appreciated.
Ian
EDIT: Ah but of course at least one quality driver says the Voltage must be at least 4 times the rated Voltage - Other comments still appreciated though. Thanks.
Zapp Automation Ltd
www.slidesandballscrews.com
