586,523 active members*
3,424 visitors online*
Page 2 of 32 123412
Results 21 to 40 of 638
  1. #21
    Aug 2003
    454
    Any one know what has happened to the videos? I get a message saying they are no longer available.
    Great thread though - excellent work.
    Mike
  2. #22
    Jan 2007
    11
    Very nice thread erniebro!!!!
    I have had a similar idea for a while. I'd like to have a cylinder either mounted permanatly to my table or eaisly relocated to exact same position (dowel pins) for tool diam. and length setting. It would be very much the same as yours. It would add the functions of doing the math to find tool diam. and length and set those in your tool library for current tool number. I think it would need an airblast to clean all chips off just before probeing as well.
    You may also need to chuck up a round rod instead of using your bit to get good accuracy. Depending on the design of the flutes on your bit, you may not get an accurate center because of how they touch the inside of the pipe.
    You may be able to get around this by running your spindle in reverse direction of tool at a very low speed.
    eibbor
  3. #23
    Jun 2007
    54
    eibbor-
    If you know the ID of the pipe you can get the tool diameter. In the code above, just insert a line after
    YCenter = (YPos1 + YPos2) / 2
    ToolDiameter = PipeID - YPos2 + YPos1 'change PipeID to your value
    I thought about rotating the spindle while doing the centering, but I didn't want my hand anywhere near a moving cutting tool! Plus, the probe circuit actuates very quickly and I'm not sure there is any guarantee that it would detect the the proper edge of your bit even if it was spinning. I guess it would depend on how fast you jogged in, the rotation speed of the bit and the amount of "debounce" in the probe circuit.
    -Ernie
  4. #24
    Jun 2007
    54
    eibbor-
    It would be cool if you can get that to work. You could measure tool wear and automatically compensate on the next use of the tool. Great idea!
    -Ernie
  5. #25
    Mike F
    The videos work ok for me so I think the problem must be your end.
    Andy
  6. #26
    Jan 2004
    105
    Very cool, I'll have to give it a try.
    thanks,
    Monte
  7. #27
    Oct 2006
    259
    A little O.T !?
    Can any one tell me how to save Ernie’s YouTube videos on my computer hard drive for future reference !
    I’ve never been able to find out how to save those little informative videos !!
    Earnie… Multo thanks for sharing this. It will help aot of us out here !!!
    Thanks in advance, Robert M :wave:
  8. #28
    May 2005
    2502
    Awesome post!
    When I get around to doing this, I think I'll put a couple bananna jacks in the box containing the breakout board for probe and ground. There are any number of gadgets one might want to plug into the probe input.
    For example, any of the toolsetters or edge finders that light up a light could be adapted.
    Another useful one would be an insulated probe tip and a multimeter-type test probe. The probe tip goes in the spindle and is insulated from the machine. Now you can use any of your tooling for touch offs: 1-2-3 blocks, machinist's chairs, or whatever.
    Cheers,
    BW
  9. #29
    Aug 2005
    578
    First I would like to ask if Earniebro would like to share his video for download? It is just common courtesy to ask. if so it is very simple...
    Bob
  10. #30
    Oct 2006
    259
    Thanks Bob !
    Oupss… Sorry !!
    No offence intended here. I was not aware there is sort of a “copy right” with Youtube videos !!:nono:
    It proves you that I’m not a full wiz with computer stuff since we can see to often copies of those Youtube videos much elsewhere than the original!!
    So, Earnie, may I have a copy of your instruction / formative video ??
  11. #31
    Jun 2007
    54
    Please feel free to download the youTube video. It's my contribution to the community.
    -Ernie
  12. #32
    Aug 2005
    578
    You tube
    Ok double click the video and when youtube page comes up copy the link in the address bar by highlighting it and right click and copy
    go here www.savetube.com and right click in the search bar and paste
    scroll down to download button and click remember to save in a location you will remember like desktop.
    allow it to download...this particular one is 11 meg. after it is complete rename it to whatever.......i.e. "earnie fantastic video.flv
    It is important to use the FLV at the end
    download this http://www.wimpyplayer.com/products/...lv_player.html
    and you are in like flint....happy days
    Oh yeah and the instruction I just gave are on the website!!!
    Bob
  13. #33
    Oct 2006
    259
    Bob,
    Many thanks for this easy step by step. It made a better day for me !
    Simple stuff can help !?
    Thanks Ernie for sharing these, many will surly benefit from this !
    Hoping someone come helping you when in need
    Robert<O</O
  14. #34
    Aug 2005
    578
    glad to help
  15. #35
    Mar 2008
    very thank for your post.
  16. #36
    Jun 2005
    142
    Fantastic
    On a scale of 1 to 10 MachBlue comes in about 12. I am a wood turner so my metal working equiptment is limited and I worked with what I have. To make the center/Z touch off plate I used a 1" by3.5" piece of steel from another project. Mounted it in a scroll chuck on my wood lathe and drilled a 1" hole in the center. Then used a carbide tiped hollowing tool and turned a recess for the plastic insert. Glued in the plastic insert and drilled a small dimple in the center. Look close and you can see the dimple in center of plastic.
  17. #37
    Aug 2005
    578
    bet you dont have to hold that anchor!!!! lol good job
    Bob
  18. #38
    May 2007
    26
    nice work
    awesome im making one right now, thanks for sharing!
  19. #39
    Nov 2007
    980
    You may also have to connect a 0.10uf capacitor between the wire and ground.
    erniebro, may I ask why you had to add the capcitor? Are you looking for a certain value? Should I check what my input is that I wll be using for this to be sure, and what exactly should I get with my multimeter? Thanks again for your help with this thread, it really has gotten me to make one of these but I just don't want to fry anything, lol!
    Dave->..
  20. #40
    Jun 2007
    54
    Re:Capacitor
    Dave-
    I initially hooked up the signal wire without the capacitor and I got false edge detections when I ran the probing code. I think the wiring in my shop is pretty poor which doesn't help. Anyway, the capacitor helps to "debounce" the circuit so short spurious signals won't be read as a contact. It takes a good solid contact now before it registers. 0.10uf was the value suggested in several other threads and it worked for me. I didn't try any other values. Larger values will slow the circuit. Smaller values may not filter out the spurious signals. YMMV
    -Ernie
Page 2 of 32 123412
  1. can you use a probe and mach3 to auto probe a part?
    By skyguynca in forum Uncategorised WoodWorking Machines
    Last Post: 11-28-2013, 01:21 AM
  2. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  3. Need probe macro for M&H Infared Probe 25.41-HDR
    By nikolaiownz in forum Fanuc
    Last Post: 02-11-2012, 03:10 AM
  4. need help with modification
    By ironofeden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 06:21 PM
  5. Super Probe 17 Functions in one probe
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:46 PM
