I have a 90VDC 2.5 DC motor which I plan to mount an encoder on.
This will be mounted on a mini lathe spindle to use on my bench top Jet mill & my 4x8 router table.
I have the 90V controller.
How would you wire to be able to use as motor for lathe work & switch over to use as servo motor to use as 4the axis with Gecko driver driver????
