586,878 active members*
4,071 visitors online*
Thread: soft limits
    Jun 2007
    18
    soft limits
    Hi everyone, well made the machine, hooked up the pc and installed Mach 3.
    Knock me down with a feather IT WORKS! everything seems to be OK until i got to the soft limits, not a disaster but i can't work it out.
    I've set the X and Y negative limits Ok now i want to set the soft max which i thought ( as it is set in mm's) the amount of travel eg: 450mm for the Y and 950 for the X but when i tested it only seemed to travel half that distance and at the bottom of the screen said " Soft Limits System Movement Aborted.
    So has anybody any ideas why the shortfall in distance?
    Regards to all Zimbe43
    Jan 2007
    869
    Go to www.syilamerica.com and look under support. They have a nice video that shows the steps to setting up Soft Limits. You may not have a Syil, but the procedures should be the same.
    Wade
    Jun 2007
    18
    soft limits
    Thanks i'll give it a go.
  1. Mach turn settup soft limits and tip numbers
    By Green0 in forum Mach Lathe
    Last Post: 03-31-2008, 09:35 PM
  2. Replies: 2
    Last Post: 08-30-2006, 11:08 AM
  3. Fanuc OM soft limits reset?
    By CNC Biker in forum Fanuc
    Last Post: 04-26-2006, 03:33 AM
  4. Question about Soft Limits???
    By Dennis Fletcher in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2005, 07:07 PM
  5. Need a simalation soft
    By hanho in forum Uncategorised CAM Discussion
    Last Post: 10-17-2004, 03:47 AM
