hello all,
I've been using Macro's for programing families of parts but would like to start using Visual basic instead, Is there a specific version of VB I should use for CNC? What one works best?
hello all,
VB6 is no longer supported.
You can get VB.NET 2008 Express free and would be a great place to start.
I'm not 100% on VBScript.
However, macro for families of parts is still very good.
One program for many parts makes Rev changes less of an issue.
Change one program vs changing many.
Just MHO.
Good luck.
I use VB6 and find it great. Never had a problem because its not supported by MS.
I understand VB.net is much harder to learn.
I wouldn't say .net is harder to learn, just structured differently than vb6. VBScript is more geared for web applications...
Either will work fine for making gcode output.
Paul
I think i'll go with VB .Net then.
thank you all.
I learned vb.net as a beginner with no previous experience using the express version. Much online help is available. I made an application to control an industrial 6 axis robot with voice commands. It took a while to learn but I was incorporating a lot for a first time project; text parsing, logic, command flow, i/o and the voice interface.
same here. I started with the tutorials in vb.net. I add parts to my application in separate projects rather than screw up my main effort. I used the on-line ask a question feature that led to a lot of different examples. After a while I started to see patterns in the coding. I'd also google key words as a lot of clues are outside the msdn scope.
Learning to parse text files to recalculate axis values was the hardest.
There are many sample projects available that demonstrate different aspects.
I use vb.net 2005, here are my 3 favorite sites for vb.net source code.
1) http://www.vb-helper.com/index_vbnet.html
2) http://www.planet-source-code.com/vb...TRUE&lngWId=10
3) http://www.java2s.com/Code/VB/CatalogVB.htm
Free DXF - vectorink.com
