586,835 active members*
2,731 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > cutting stainless steel
    Jan 2008
    9
    hi friends,
    I have to cut a slot on stainless steel (316), 2.5" deep on a round hub of 6 inches. Diameter on which slot has to cut is 3 inches and width of slot is .660.
    My question is that for roughing out this slot which tool should I use? Roughing end mill of 5/8 or inserted end mill(round inserts) of 5/8 and how much depth of cut and feed I can give.
    Jul 2004
    601
    Just start with the same tooling you use for carbon steel (1018, 1045...), and reduce the feed and speed to about 2/3. If the tool and machine can take it run the chipload as high as you dare, to prevent work hardening.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Jan 2008
    9
    i was thinking to do couple of holes before starting to machine. will it help to reduce the chipload
    1st I'm not a CNC machinist!
    If I were to make it, I would drill one hole to start the slot, then use the quill to plunge cut the slot. By plunge cutting and advancing .050 -.100" per cut, you will only use up the end of the end mill which is easier to sharpen than the diameter.
    Use air to blow the chips clear, as re cutting them will kill the end mill. If possible, use a flood coolant! As the tool end wears, just grind it to a radius to extend it's life!
    (This is assuming there's only one piece!)
    My 2¢
    Widgit
    Mar 2008
    31
    i personally would use the inserted end mill, with the correct inserts for stainless steel. If this isn't possible using a High Speed Steel Roughing end mill with rad on bottom to help maintain tool life, Slower spindle speed and get the feed up to as high as is capable of without being excessive, It is really a trial and error thing with feeds and speeds. Depends on the stability of machine etc etc, Flood coolant aswell.
  1. Laser Cutting Stainless Steel ???
    By Babba in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-04-2015, 06:45 AM
  2. Steel or Stainless
    By tool_man in forum Casting Metals
    Last Post: 10-29-2006, 12:46 PM
  3. Stainless Or Steel
    By 69owb in forum Mechanical Calculations/Engineering Design
    Last Post: 10-03-2006, 07:43 PM
  4. Pls suggest a mill fit cutting Stainless steel
    By szcharle in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2006, 03:22 AM
  5. Cutting stainless steel
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-25-2005, 11:14 PM
