Ok!
Well I watched all ten videos, what do I win?
Anyone have any more interesting videos like that, either free or otherwise?
I thought that was very instructive if a bit uneven in level of detail. A couple of questions linger.
1) He emphasizes safety, that's cool, esp, not putting the part into the belt sander or buffing wheel "uphill". At the same time, he shows grinding a lathe tool on the grinding wheel, and he's definitely going "uphill". Is this safe? Is it because the wheel is so hard it's not as likely to grab the part and drive it down like the soft wheel or abrasive belt? Or is it just that you have to do so to get a sharp edge and the benefit outweighs the risk?
2) Anybody else cringe when he's pointing out the surface finish right next to the running boring bar? Maybe it was just the camera angle that made it look more dangerous than it was. I guess he's a pro and still has ten digits!
2.5) He shows how to align the head to the bed, and square the vise jaw to the head. Is this the same as "tramming" the mill? Are there other reference materials to teach this important task? Are there similar operations that must be done with the lathe? He only shows squaring the cutoff tool. While he mentions the threading tool must also be square, he doesn't show how.
3) He has a super well equipped shop. I'm guessing I"m not going to rush out and buy a Wilton drill press, Bridgeport mill, and whatever that lathe was, plus all the tooling right off the bat. Although I would like to, my wife's insurance policy is not that much.
So, I already have a band saw and a bench grinder. I have a large collection of woodworking tools, and I've been told I can get metal cutting blades for the radial arm saw and that might be handy. I guess I will get a lathe, I'm thinking one of the sherlines or the standard import "mini-lathe". The sherline is USA made and that's appealing but it's mighty small. The import is bigger but possibly less accurate and more design-compromised. With the import I am told I will have to spend significant initial work just to make the lathe work right. With the Sherline I'm betting I can just get to work learning how to make stuff. Oh, I think the import is less expensive even though it's larger.
Also, what tooling should I get? I KNOW I will need a dial indicator with some accessories. I already have a dial caliper, in .001s, but it's from Dillon, for reloading, is that going to be sufficiently accurate? Should I get a micrometer? What else?
I have 1,000,000 questions, but I guess I'll stop there for now. :rainfro:
Advice?
Thanks!
Beez
