586,457 active members*
3,431 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Inductive Proximity Sensors-what are they?
    Jun 2003
    453
    I saw the term inductive proximity sensor on this page http://www.campbelldesigns.com/breakout_board_plus.htm but I'm not sure what one is or where it's used, are they limit switches? Please enlighten me...
    Splint
    24223
    Proximity switches can be used as limit switches, there are types available in different kinds of physical shapes and also types that can detect a ferrous or non-ferrous metal 'flag'.
    The sensing distance is dependant on the diameter of the sensing face, typically .2 to .5 cm. One down side is you cannot use them in a environment with a lot of metalic chips and dust etc.
    Al
    Apr 2004
    678
    Be sure you use the right type of metal for the flag. A collegue of mine told me that one place he worked before, someone had mounted a flag of another metal than specified for the end stop of a gantry crane. They obviously did not know how it worked. During the test run one test was of course testing the end stops. It didn't, and the gantry went through the wall and ended up on the parking lot outside. Ouchh!
    Jan 2004
    231
    I've been wondering if proximity switches would work to keep a laser's cutting head from coming in direct contact with the sheet metal its cutting. I havent taken a really in depth look at the spec sheets that are available for the capacitive sensors that are digikey. If anyone knows of a good circuit diagram for really precise positioning please let me know.
    owen
  1. proximity sensors
    By wired in forum CNC Machine Related Electronics
    Last Post: 09-30-2005, 05:29 PM
  2. capacitive proximity sensors
    By owhite in forum CNC Machine Related Electronics
    Last Post: 03-16-2004, 03:49 PM
  3. Proximity switches
    By bgriggs in forum DIY CNC Router Table Machines
    Last Post: 09-01-2003, 06:13 AM
  4. proximity switches
    By rcrabb in forum DIY CNC Router Table Machines
    Last Post: 07-21-2003, 05:27 AM
