586,500 active members*
1,860 visitors online*
Results 1 to 7 of 7
    52
    How to connect laser power supply?
    Hello!
    Does anybody know how to connect laser power supply to computer? I still can not understand it. Let's assume that I wand to engrave something. What commandin TurboCNC corresponds inclusions of the laser on the given capacity? It G or M-code. May be something else like speed (F-code)?
    Attached Files Attached Files
    Oct 2007
    240
    You need a control board... the PS does not connect directly to the computer.
    Hi-TecDesigns.com -- Automotive Lighting Systems
    52
    Did you mean that I need a special board except my cnc controller?
    But in any case, what commands answer for capacity?
    Oct 2007
    240
    You need some form of interface between the computer and the PS, you cannot connect them directly together. Your CNC controller may offer that option, but I cannot say, that will be up to you to decide.
    52
    Strange.... I was thinking that I can use PWM option of mach2. I mean that S-code may control laser power like it control spindle speed. Am I right?
    Oct 2007
    240
    Yes, if you're using Mach, then your software has the capability for PWM... but the software needs some form of interface between the PC and your PS. That's where the hardware comes in.
    52
    What form? If you are mean standart interfase board where I can get pin signals from lpt that of course I will use it. If not, please, write what is the special board.
  1. CO2 laser power supply
    By KTP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-27-2012, 03:09 PM
  2. How to check Laser power supply?
    By glintid in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-05-2008, 01:32 PM
  3. Replies: 5
    Last Post: 04-14-2007, 12:11 PM
  4. Laser Power supply
    By technazz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-20-2007, 02:33 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
