586,980 active members*
3,759 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Sherline lathe chuck grip problem
Results 1 to 4 of 4
    Jun 2014
    25
    Hi everyone,
    This is my first post on these forums but I've been creeping on you guys for several years. I have a decent amount of machining experience, more so with CNC than manual machines.
    Anyway, I recently got a sherline 17 inch lathe. Everything works pretty well on it except for the chuck. Turning is fine, facing is fine, but when I try to part off any piece of bar stock, the bar stock somehow slides out of the chuck, as if it's being ejected towards the tailstock.
    It happens with every material (several aluminim alloys, steel, brass, even PTFE) and with both round rod and hex rod. It does it with every diameter of bar.
    I'm using a 0.04 inch parting blade, the flat T shape type. It does the same thing with the 0.06 parting tool also. The parting tool bends so much when the parts start to slip out that I'm afraid it's going to break, not to mention I have to re-chuck about 5 times just to part off one piece. I've tried tightening the chuck more and less, and I'm capable of putting a lot of torque on the chuck to tighten it so that isn't a problem.
    Has anyone else had this problem? I've never seen it happen with any other lathe, and I still don't understand what's causing it.
    Thanks!
    Dec 2012
    569
    Re: Sherline lathe chuck grip problem
    Quote Originally Posted by Generic Default View Post
    Hi everyone,
    Thanks!
    Nov 2009
    4415
    Just to let you know, the parting tool is the most challenging tool to use with a Sherline.
    A lazy man does it twice.
    Apr 2004
    5742
    Are you supporting the tailstock end of the part with the taistock center? That should prevent the piece from being "ejected". Or is the whole tailstock moving? In general, if you've sharpened the parting-off tool unevenly, it can have a pushing effect - you need to sharpen it flat to make it cut evenly,
    Andrew Werby
    Website
  1. Replies: 8
    Last Post: 04-18-2014, 02:03 PM
  2. Grizzly G8688 Mini lathe 3 Jaw chuck problem
    By Semus in forum Benchtop Machines
    Last Post: 11-30-2013, 08:41 AM
  3. Sherline rotary table chuck options
    By MechanoMan in forum Taig Mills / Lathes
    Last Post: 08-13-2010, 10:11 PM
  4. Sherline tailstock chuck
    By MechanoMan in forum Mini Lathe
    Last Post: 06-19-2009, 11:41 PM
