Ok got my C6 board back in and I'm having difficulty getting it to show any voltage to send to the control board on the X2. Here is the setups.
12vdc 600ma power wall mount power supply. C10 breakout board.
Step hooked to pin 14 (output)
Dir hooked to pin 16 (output)
Gnd hooked to the ground with the powersupply to keep it isolated.
Both jumpers on the board set to opto
My home/limit switches work so the board is getting signal I suspect
Mach 3 setup
-Ports and pins: Motor outputs
spindle motor checked, step pin 16, Dir pin 14, Low active, step & Dir port 2
-Spindle setup: motor control
use spindle motor output and step dir. control checked, PWM base 9
min PWM 10%
-General Parameters: CW delay spinup 2 sec, CCW delay spinup 2 sec,
CW spindown 3 sec, CCW spindown 3 sec.
Motor tuning: steps per 1000, velocity 1500, accel 1000, step pulse 1,
Dir pulse 1
HZ set to 25000
I get .83-.85 vdc output regardless of RPM input in the Program Run Display under spindle speed. The dwell icon flashes
Now for other issues I swapped PC's and the Control worked fine until after the swap. Now when trying to Jog I get a high pitched whine out of the motors, the DRO's move but the motor jumps around a little then stops and makes noise. All axis do the same even with the motors removed. Speed and accel doesnet make any difference. Back to the shop to figure it out maybe. Thanks for any help in advance.
Rick
