586,357 active members*
2,827 visitors online*
    Feb 2008
    Okuma OSP 5020L
    Need some help with this program. I am getting a 452-1 Alarm on my
    OSP5020L Control. If some could take the time to check this program
    and let me know where my problem is I would appreciate it.
    Thanks in advance.
    $MOLD-FEMALE.MIN%
    G13
    G50 S1000
    G0 X50 Z50
    NAT03 (5/8DIA BORINGBAR)
    T030303
    G0 X0.05 Z.5 G97 S400 M3 M43 M8
    G96 S700
    G85 NIDIA D.1 F.01 U.020 W.020
    NIDIA G82
    G42 X0.05 Z.2 F.005
    G1 X0.050 Z-2.2921
    G2 X12.4807 Z.0657 I-.0250 K9.4370
    G40 X12.3000
    G80 M9
    G0 Z.5
    G0 X50 Z50
    M1
    NAT13(5/8DIABORINGBAR)
    T030303
    G0 X0.05 Z.20 S600 M3 M43 M8
    G96 S900
    G87 NIDIA
    G0 Z.5
    G80 M9
    G0 X50 Z50
    M2
    Nov 2007
    352
    First of all u an w as incremental moves on an okuma dont work-should be x and z in a ---g91 command--------------the problem is in the G02 line -replace the i and k with an L-----------L on okuma is the same as R on fanuc-----this should also help pick up the ---g42 command properly-make sure radius calculation is also correct-make sure also when using G42 you have put proper radius values in both x and z in the compensation screen under tool radius
    Feb 2003
    349
    Quote Originally Posted by lshingleton View Post
    hi
    he dont wanna incremental move, u and w ist for finishing.
    i and k is corect if the value is right.
    Nov 2007
    352
    The u and w was just an observation that on this control it is ignored
    Never got the older i an k to work on this contol only L-when using a G42/41 command
    If you get this alarm follow by over end point or cicle calclation check the value set in the word or long word parameter to make sure it has a big enough window for error calculations-----
    Nov 2007
    352
    Actually looking at the program again it is an easier problem-there is no G01 or G00 programmed after the radius move
    Program a G00/G01 after the G02 line
    Have a good day
    Mar 2008
    28
    Looks like you will want to feed off of your profile a bit before you exit cutter comp. If you've got room at the end of your profile pass, feed down a bit off the ID, at least two times the distance of your tool nose radius, i.e. if you're on a 5.00 diameter, with a .0312 tool nose rad, feed down to 4.93, then call the G40, this will also give the machine a direction to exit cutter comp. The I and K values are the INCREMENTAL distance from the start point of the radius. The only time that L will work is if the radius is tangent to both features.
    Cheers,
    Brian
  1. Okuma RS-232
    By dmealer in forum Okuma
    Last Post: 08-29-2022, 03:40 AM
  2. Help with okuma
    By Josh cpt in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-03-2008, 03:17 AM
  3. okuma vs yci
    By pp-TG in forum Uncategorised MetalWorking Machines
    Last Post: 10-02-2007, 07:58 PM
  4. okuma cadet lathe osp 5020l
    By bryanpackmac in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2007, 01:36 AM
