586,133 active members*
3,364 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Slot Cutter Holder Arbor type, cant find??
    Feb 2008
    92
    I need a arbor type holder for a 8" dia slot cutter. The arbor diameter is 1.5". I looked through Kennametal but only found one with a max 1.25"dia. I need it for a 40 taper CV for a HAAS mill.
    Anybody know where I can order one of these??
    Oct 2007
    20
    Mar 2008
    18
    Here's another option. Good luck
    Feb 2008
    92
    Thanks guys that helps. Will order one today.
  1. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-16-2008, 02:06 AM
  2. Which tool bit type for surfacing aluminum with a fly cutter?
    By cnczoner in forum MetalWork Discussion
    Last Post: 01-03-2008, 08:54 PM
  3. Where can I find this type of aluminum extrusion?
    By chozo in forum DIY CNC Router Table Machines
    Last Post: 11-04-2004, 04:58 PM
  4. Help find terminal connector type for this stepper
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 10-09-2004, 07:34 PM
  5. help - where to find 8020 t-slot alum
    By landart in forum DIY CNC Router Table Machines
    Last Post: 08-01-2003, 02:45 PM
