586,129 active members*
2,762 visitors online*
Thread: rebuild
    Apr 2004
    297
    rebuild
    Hello all, well I finaly got my Mic-6 tooling plate and started on the rebuild today. All I got done so far is mounting the 7"x 40"x1/2" carriage plate.This plate goes all the way across this time instead of having two seperate plates. I masked off the plate where the bearings are to be mounted and with an engeneers square marked out the center lines for drilling. First a pilot hole then a larger to clear the socket head cap screws then a counter sink so the screws were lower than the top of the plate. I used some clamps to mock -up the sides that will hold my existing Y&Z assembly. More to come.
    Attached Thumbnails Attached Thumbnails 100_1248.jpg   100_1250.jpg   100_1260.jpg   100_1256.jpg
    Apr 2004
    297
    Well I got a little more done.Drilled and tapped for the gantry sides which will hold the Y and Z assembly.Will drill and tap and mount to the lower carriage later.
    Attached Thumbnails Attached Thumbnails 100_1263.jpg   100_1264.jpg   100_1266.jpg
    Apr 2004
    297
    Got some more done this week, had a friend from durham robotics mill some slotts for the Y stand-offs which set them into the side plates about 3/16 of an inch for more strength. End plates were drilled for the X lead screw. Motor stand-offs drilled as well.Still need to install lead screw bellows for the X and re-install anergy chain for motor wires, then rewire home switches.More pics soon.
    Attached Thumbnails Attached Thumbnails 100_1338.jpg   100_1339.jpg   100_1343.jpg   100_1346.jpg
    Apr 2004
    297
    All is well so far, limit switches wired and working ,energy chain installed and router mounted. All I need now is a table top, wood or aluminum?
    Attached Thumbnails Attached Thumbnails 100_1352.jpg   100_1353.jpg   100_1354.jpg   100_1355.jpg
    Aug 2004
    3215
    curious to how you get to the leadscrews easily to keep them lubricated?
    joe
    Apr 2004
    297
    Smile
    Hello Joe,to get to the leadscrew for lubrication isn,t too hard , all i have to do is loosen off three button head cap screws that hold the bellows flange and slide the bellows back then lubricate. Slightly time consuming but it keeps any debris out.i usualy lubricate every other week, not sure if that is too much or not enough,i use motor oil on the ball screws,cheers.
  1. Rebuild of an very old Aciera F3
    By syyl in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-01-2008, 07:17 AM
  2. Foamcutter Rebuild
    By OzDragonflyer in forum CNC Wire Foam Cutter Machines
    Last Post: 10-11-2007, 10:09 PM
  3. Brake rebuild
    By hmc710 in forum Bridgeport / Hardinge Mills
    Last Post: 07-03-2007, 04:33 AM
  4. Haas Vf-2 Rebuild
    By DEAN in forum Haas Mills
    Last Post: 09-19-2005, 04:46 AM
  5. Router Rebuild
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 08-18-2005, 02:42 PM
