Hello all, I am working on a wooden boat project. The planks are quite unique in that they are cut from a solid tree trunk (typically two planks per 10 foot cedar trunk).
Questions:
1. Are there any suitable multi-axis mills that will cut a cedar log/tree trunk with compound curves?
2. Is there a machine that will cut a log that is 10 feet long? The longest plank is 10 feet long, but others will be in the range of 6 to 8 feet.
3. Do you know of any wood/furniture CNC houses that have 5-axis capability for stock of this size?
This boat will be used on an expedition and building it using original methods (planks cut from solid trees) is a must. No steamed/clamped flat planks here. Compound curves are used throughout.
Thanks in advance for your suggestions.
Cheers,
Sandman
