587,006 active members*
3,032 visitors online*
Results 1 to 7 of 7
    Feb 2008
    dynapath delta 20
    HELLO EVERY BODY .
    I BOUGHT TREE MILL MACHINE HAVE DYNAPATH CONTROL DELTA20 MODEL 1990 AND I DO NOT KNOW WHAT CAD /CAM PROGRAM I CAN USE WITH IT BECAUSE I HAVE TRIED SO MANY PROGRAMS BUT IT LOOKS THAT I MISS SOME THING
    IF THERE IS ANY BODY CAN HELP ME OUT .
    THANKS ALL AND BEST REGARDS
    Apr 2008
    19
    im in the same situation, i have a delta 20 vmc and bob cad will not communicate with it, there is no post for it. if you find out anything please let me know also
    May 2010
    290
    You can get a manual from Dynapath.....they're 200 bucks, though. It will have all of the information about what the control is looking for.
    The code needed is nothing really out of the ordinary. I can tell you that you must not have spaces anywhere in your code.
    Any CAM system with a configurable Postprocessor should work fine.
    You must also have a program name as your first line. It must be in parenthesis, all capital letters. Like this..... (TEST).
    Those are some of the most common snags.
    May 2010
    290
    BobCAD/CAM lists many Dynapath 20 posts for free on their site, BTW.
    Apr 2008
    19
    michaelthomas
    thank you for the imfo , ive been trying forever to communicate with this dynapath. all i want to do is save programs
    Feb 2009
    6028
    Early dynapaths do not have Eia programming, so you need a dynapath post. Later deltas have the Eia function, the basic of which would be a fanuc om I believe. You do have to modify the post for the end of block, beginning of the program, fixture /tool offset commands. Also, I have run in to some dynapaths that were wired for parallel communication, rather than serial, this is simply switching lines 2 and 3.
    Apr 2008
    19
    thanks, i figured that there is a trick somehow. i have version 18 bobcad and they want give me any support anymore to communicating with this control
  1. DNC w/Dynapath Delta 20
    By rr167 in forum DNC Problems and Solutions
    Last Post: 01-11-2019, 08:43 PM
  2. dynapath delta 20
    By chipman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-15-2008, 08:47 PM
  3. delta dynapath
    By camtd in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2008, 06:45 AM
  4. dynapath delta 10 help
    By undertowx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-05-2006, 03:49 PM
  5. Dnc dripfeed for Dynapath Delta 10
    By badgs750 in forum DNC Problems and Solutions
    Last Post: 05-21-2006, 07:37 AM
