586,795 active members*
2,865 visitors online*
    Aug 2005
    9
    Question Fanuc O-T rs232 output issue
    Has anyone ever seen this before. I send a program to a machine with a Fanuc O-T controller in the standard format:
    O1234
    M30
    When I upload the program back to the PC, I'm getting:
    &HE:%
    :1234
    M30%
    my concern is the first line. The various characters are messing up my DNC software's ability to compare the uploaded program to the original on file. Any ideas as to how to remove the "&HE:" ???
    The relevant RS232 parameters that I'm aware of are:
    I/0 = 0
    2.0 = 0
    2.2 = 0
    38.6 = 0
    38.7 = 1
    70.7 = 1
    552 = 11
    Any help is greatly appreciated!
    2932
    What is parameter 2.7? Should be set to 1.
    What software are you using for Upload/Download? There may be settings to strip characters before the % sign.
    Aug 2005
    9
    Parameter 2.7 is indeed a 1. I wrote my own DNC software...so ignoring characters before the "%" is an option...but I was hoping to get away with a parameter change or something similar...
    Thanks for the reply!!!
    Feb 2008
    12
    I had problems uploading from my ot control two but for some reason when I changed the parameter from ascii to iso at the machine it worked? It sdhouldnt have but did.
    Aug 2005
    9
    I ended up modifying my DNC software to omit everything before the first "%". I still bothers me a bit...so if anyone has any other ideas...I'd love to hear em...
    Thanks for the suggestion dcoupar!!!
    2932
    garoweir,
    IIRC, we had to strip them out when receiving with SmartCAM's communicate, too. I believe they're control codes... nothing to be bothered about, as long as it's working.
  1. Fanuc 11M RS232
    By 9566317 in forum Fanuc
    Last Post: 09-24-2015, 10:02 AM
  2. program input/output with RS232 port on Mitsubishi 50L
    By Chuck Reamer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-21-2013, 08:56 AM
  3. Fanuc 0M, M19 Issue..
    By gearsoup in forum Fanuc
    Last Post: 12-15-2012, 08:52 PM
  4. Weird issue with NC output
    By ClockMaster in forum FeatureCAM CAD/CAM
    Last Post: 12-19-2007, 11:21 PM
  5. Eagle CAM Processor output - Mach3 Size issue
    By deleteallusers in forum G-Code Programing
    Last Post: 05-02-2007, 03:14 PM
