587,008 active members*
3,531 visitors online*
Results 1 to 9 of 9
    CNC foam cutter
    Here is one I built about 6 months ago. I use the 8linx board. I updated the motors to 100oz and got more speed on a 3/8-16 rods on my X-axis and used ACME 3/8-10 for the Y-axis. Both axis operate about 3mm/s and its fast enough. Got most of my information from the French sites and tables already built.
    I did not want to have to build a 6" box platform so I made some modifications.
    This cost me about $200 for the electronics and another $250 on linear bearings and shafts. The rest of the parts I made from plastic (cutting board) and wood as I do not have access to a milling machine.
    Vic
    www.VicRC.com
    Apr 2003
    292
    Looks Nice! Do you have any pictures of things you've made with it?
    My name is Electric Nachos. Sorry to impose, but I am the ocean.
    http://www.bryanpryor.com
    pictures
    I do have some sample cuts located on my web and more pictures of my machine at
    http://www.vicrc.com/cnc/cncfoam.htm
    Also made some horizontal foam filler for my P38 fiberglass fuse and was extremely happy with the combination of strength and light weight.
    http://www.vicrc.com/P38-5.htm
    you can't see the blue foam filler on the horizontal stab, but its there.
    Recently cut panel cores for filler for my outer panel molds, will take some pics tonight and post.
    Vic
    Happy cutting and flying!!! Somehow 'building' gets in the way of both
    www.VicRC.com
    Sample cuts!
    Here is a sample cut. The cores are filler into my outer panel molds.
    Vic
    www.VicRC.com
    This is what the panel looks like after laying up the part
    Vic
    www.VicRC.com
    56
    What software are you running? Your spar cuts are very clean.
    I am using the Gilles Muller software, I think its $35 you can get it at http://gm.cnc.free.fr/index_en.html
    Vic
    www.VicRC.com
    Apr 2003
    32
    Try this out
    2 wrongs don't make a right
    But 2 Wrights makes a Airplane
    Kevin Matney
    www.Matneymodels.com
    734 - 848 - 8195
    "IN GOD WE 'TRUST "
    Sep 2023
    10
    Re: CNC foam cutter
    good job
  1. Foam cutter Kit
    By RedLabel in forum CNC Wire Foam Cutter Machines
    Last Post: 11-06-2012, 05:43 AM
  2. 8linx .com foam cutter
    By vicsrc in forum CNC Wire Foam Cutter Machines
    Last Post: 08-27-2009, 01:10 AM
  3. Hot Pin Foam Cutter
    By damae in forum CNC Wire Foam Cutter Machines
    Last Post: 01-25-2009, 02:40 AM
  4. My first CNC! soon to be foam cutter
    By nikolatesla20 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-06-2005, 07:48 PM
  5. Foam cutter
    By paulried in forum CNC Wire Foam Cutter Machines
    Last Post: 10-30-2003, 10:58 PM
