586,537 active members*
2,893 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport EZTRAK Alarm: commanded X-axis move too far positive
    Feb 2008
    Hello, I am receiving the error "Alarm: commanded X-axis move too far positive" when attempting to home the mill after the initial start-up. The error occurs as the X-axis limit switch is hit. I read through some of the posts here and tried changing the bed size (press * then 11235). I also tried manually moving the table as far away from the limit switch as possible and then rehoming, it still gives me the same error message. Any help is appreciated.
    Also, how do you distinguish a series 1 machine from a series 2? I have the color monitor and "extended keyboard". The machine says it is running version 6.
    Thanks.
    p.s. I am new to this machine.
    Feb 2008
    Nevermind, I got it figured out.
    Jan 2009
    I have the same problem
    how you di it?
    Dec 2005
    3319
    Center the table under the spindle. Reaset o for all axis. Then try to rehome. AFIK, that should work.
    HOpefully the "never mind, I found it guy" will share his method. THis is a give and take M/B by the way.....
    Nov 2004
    3028
    EZTRAK 1 has dovetail ways.
    EZTRAK 2 has box ways and supports a lot more weight.
    George
  1. parser: commanded z axis move to far possitive
    By tonymann in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2007, 06:05 AM
  2. Replies: 14
    Last Post: 01-08-2007, 06:10 AM
  3. On the Z-axis, All Movement Above Zero Are Positive - Right?
    By TheNigerian in forum Machines running Mach Software
    Last Post: 05-22-2006, 02:46 PM
  4. ALARM!!! "Commanded X Axis move too far / Positive"
    By aimeahz in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2006, 11:51 PM
