586,701 active members*
2,581 visitors online*
Results 1 to 20 of 22
    Sep 2007
    27
    Speeds and Feeds
    I have been machining Aluminum only for the past 12 months. I've just thrown a block of mild steel in and drawn a blank on speeds and feeds. I'm roughing with a 5/16 Ball End Mill on a VF1, any ideas would be cool,
    Cheers,
    Frog Man
    Jul 2004
    601
    Carbide or HSS?
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Sep 2007
    27
    Sorry,
    Carbide
    Oct 2003
    263
    Software For Metalworking
    http://closetolerancesoftware.com
    Sep 2007
    27
    Thanks MRainy,
    I threw some data into the mix and came up with about the numbers I am using.
    As I mentioned before, I machine mostly Alluminium and usually the same parts so the numbers just come out of my head really. This is the first plane carbon steel we've machined on our VF1 and the first steel I've machined for years. At the moment I'm running..
    2500RPM
    Feed Rate 400mm/M or 15.7"/M (sorry about the metric)
    Depth of cut 1mm 0.04"
    step over 3mm 0.12"
    Carbide Ball nose 8mm 5/16" Diameter (tools hanging out 40mm 1.5")
    Does anyone have comments on this? Does it seem close to what you would use or off the mark? It seems a little slow to me and I also have some vibration.
    See set up,
    Frog
    Jul 2005
    12177
    You could probably take both rpm and feed up quite a bit. It is a bit of a play off between how fast you want to remove metal and how long you want the tool to last. At your current speed and feed your tool is probably going to last a long time but is removing metal slowly; if you double the rpm and tripled the feed you will remove metal faster but the tool will not last as long; exactly how long is difficult to predict, but it is likely the extra cost in tools is more than compensated for by the time saving in machining.
    It is possible you could take the speed up even higher than double, take the feed up to four or five times and use an air blast rather than coolant for much faster removal with good tool life.
    Oct 2003
    263
    At a .040 cut depth the cut width is only .209, so you're under 140 SFM, which is quite low.
    On the other hand, your tool is hanging out pretty far, so the potential for cranking up speeds and feeds might be somewhat limited.
    The only way to find out is to give it a try.
    There's lots of different types of alu, check which grade you are using and contact the maker of your cutter for proper feeds and speeds for the cutter. Works every time!
    www.wilkins-knives.com
    Mar 2005
    1673
    Quote Originally Posted by mrainey View Post
    Respect
    Frogger,
    I would highly recommend having at look at this excellent software ME Consultant Professional from here http://www.mrainey.freeservers.com/
    John
    Sep 2007
    27
    Thanks for all the help.
    Nov 2005
    174
    You can also go into the Help/Cal menu and page down to the speed and feeds cal. I used it the other day with some D2 on my TM-2 and it was pretty close. I like that you can put in the chip/tooth, rpm, sfm and tool dia. then BAM there it is.
    Feb 2008
    40
    feeds and speeds
    I push my machines to the absolute limit. Replacing tooling is a cheap way to make parts efficiently. I have a vf3 that I run a one inch e.m. 120 inches a minute in 6061, speeds and feeds are something you feel with your forehead, know what I mean?
    Robert
    Jul 2005
    340
    imagine that : 12mm endmill 3 flute 6000rpm and 2600mm/min feed , alu block , 100% width and 5.5mm depth is too much for tm-1 - 185% use of spindle and it can not hold rpm`s
    Jul 2005
    12177
    Okay Piter what is that in real units ?
    12 mm about 1/2"
    5.5 mm just over 3/16"
    6000 rpm I guess is 6000 rpm Imperial or Metric
    2600 mm per minute is about 100 inches per minute
    Now it is in the units I think in.
    I believe the TM motor is the same as the 6000 rpm MiniMill; your results sound about correct for what I would expect with our MiniMill. They do not have much high speed torque.
    One time I was taking a similar cut with a 1/2" high helix two flute, but at a slower feed, around 50 or 60 ipm, and was getting a 120% load on the spindle. What I did try was reducing the speed to something like 5000 rpm without changing the feed and the spindle load went down slightly.
    Dec 2006
    447
    I have a self imposed limit of 130% continuous spindle load. My experience is a .5 EM 3 flute variable running in 6061 at 6000 RPM full width , .35 DOC and 50 to 70 IPM will sit at about the 130%. This is on a TM-1P using flood coolant.
    Anything above the 130% and the spindle cannot keep up.
    Vern
    Jul 2005
    12177
    Vern; Practically identical to my MiniMills; try dropping the rpm like I mention and see if it drops the spindle load.
    Dec 2006
    447
    Will do.
    Feb 2008
    4
    would like help with s/f for an SL-10
    Good after noon! I am riged tapping a 5/16-18 tread. does the haas adjust speed and feed automaticly?
    Jul 2005
    12177
    Quote Originally Posted by davidaeroprod View Post
    You have to set the speed and the correct feed for the speed.
    Feb 2008
    4
    I had put spindle speed of 200.and div.1 by18 =.0555 just did not think it was true
  1. Speeds/Feeds ... for a nub
    By thomax00 in forum MetalWork Discussion
    Last Post: 04-16-2013, 07:43 PM
  2. Speeds And Feeds
    By John H in forum MetalWork Discussion
    Last Post: 12-09-2008, 04:10 AM
  3. speeds and feeds
    By stevieboy in forum MetalWork Discussion
    Last Post: 03-09-2008, 03:55 PM
  4. Need some help with speeds & feeds
    By ldkell_2000 in forum MetalWork Discussion
    Last Post: 03-01-2008, 05:35 PM
  5. feeds and speeds
    By JpBinc in forum MetalWork Discussion
    Last Post: 10-03-2006, 06:48 AM
