586,516 active members*
3,887 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Can Anyone Figure this out? Interesting problem...
    Jan 2007
    260
    Hello All,
    I was hoping that some of you might be able to provide me with an idea as to how to do this, as I have tried many different ways, and I can't seem to get the results I want:
    I have attached the solidworks (2007) test part on this thread. Here is the issue:
    If you look at the part, you will see that the top is a surface with curves/contours. I have cut a U shaped cut on one end, and if you will notice, there is a cut all around the part, that is .1 "in" and .1 deep all around for the cut. Now here is my puzzle:
    I want this SAME cut to happen in the area where there is the U-shaped cut is, however, as you will see, the surface on top there is higher. So if I was going to cut on the same plane I used for the rest of the part, that end would be cut much deeper. I want the area of where the u-shaped cut is to be cut at the same depth and dimensions as the rest of the cut around the body. In other words, I want the cut around the part to be the same, even though there might be some height differences to compensate for the surface heights. I hope this makes sense as to what I am trying to achieve :-)
    Is there a way to do this? thank you all in advance for any of your ideas....
    Attached Files Attached Files
    Feb 2007
    162
    Something like this one?
    This was a quickie....
    I'm sure it could be done cleaner using offset surface then trim away.
    ***I added test-part3.zip This one offsets the surface and the entire step is non-planar
    Scott
    Some of my best finds were in the trash....
    Jan 2007
    260
    THANK YOU! That is the part I was missing, the Offset from surface feature!
    makes perfect sense now. I was trying to use "splines on surface" to achieve this, but this feature will NOT allow you to offset a sketch.
    Sometimes the obvious things are the harder ones!
    Again, Thank you for shinning the light!! Much appreciated!
    Aug 2006
    259
    I haven't looked at your part, but if I'm following your description correctly, you also might be able to do a swept cut..
  1. Action Figure
    By jfmenna in forum Employment Opportunity
    Last Post: 02-10-2008, 03:13 AM
  2. Can someone help figure this out, please?
    By windrider in forum Mastercam
    Last Post: 08-25-2007, 04:19 AM
  3. Anyone figure out the EMCI.INI
    By anoel in forum LinuxCNC (formerly EMC2)
    Last Post: 09-23-2006, 07:43 AM
  4. Can't figure out why...
    By asher in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2006, 04:15 AM
  5. Help me figure my transformer size
    By scheek in forum CNC Machine Related Electronics
    Last Post: 03-10-2006, 12:57 AM
