587,008 active members*
3,191 visitors online*
Thread: PROTO-TRAK
Results 1 to 20 of 22
    Oct 2006
    48
    Question PROTO-TRAK
    HI fellow machinist's Have any of you ever ran PROTO-TRAK MX2 or MX3 control systems? I run both a Lagun knee mill and a TRAK DPM bed mill with PROTO-TRAK systems on them I have off line programing on my computer but I do 99% of my programing on the machines themselves. PROTO-TRAK is all I've ever run so I'd like to know how it compares with other systems like Fanuc,
    Feb 2008
    4
    Hey Gary55,
    I run a TRAK DPM as well. I ran a Prototrak Edge MX2 control. I actually like the Edge better than the DPM. I started as a computer guy before getting into Machining so I like to draw out my parts on Mastercam and export the toolpaths out. I started machining on a Supermax 3 Rebel with a Fanuc controller. Talk about jumping head first into the heat of things!! Anywho... When it comes to getting easy paths ie. rectangles circles and regular shaped pockets, Its obviously easier to figure your cords out quick and throwing them into AGE 2 or 3. When I was using Prototrak Edge, I could post my more difficult paths to a floppy and throw it in and run it pretty quickly. I have run into a big block with the DPM!! I have no AGEOL software. I had a part a week ago that I had to draw out on Mastercam and then label the outline of the parts points and manually enter them into the controller. 34 sets of mill paths with different Zs. I would have been able to get the job done in an hour but it took the better part of a day to do because I dont have a post for mastercam for AGE3. Bummer!! So in my humble opinion, usability wise, AGE is great for quick easy jobs and would be a trump to a fanuc if I could post to it for the harder ones. As far as Fanuc, Its great if you know G Code and how that al works. Code Geeks would eat up a fanuc!! Its like candy.
    P.S. If you could get your hands on a post file for the DPM AGE3 for Mastercam, I would be very greatfull!!
    Oct 2006
    48
    stpierrenb if you sent a reply i did'nt get it all i got was my post
    Jan 2006
    21
    I run a ProtoTrak MX2 on my Alliant mill and I also run a ProtoTrak QuickCell 3 axis. Southwestern Industries programming software leaves some to be desired especially on the 3 axis. The MX2 I have never had a problem with but then again it is just a 2 axis. Offline programming did not happen with the 3 axis. We got the software but then after repeated attempts to get it to work, the Southwestern rep informed us the offline programming that they supplied would only work with an old DOS based computer WTH is with that??? How many people still have a computer laying around with Windows 3.1? So for some things on the three axis I will program with an older version of SmartCam, but usually just find it just as quick to draw something up in DeltaCad, and manually program it in to the three axis. This usually saves time over trying to tweak the numbers with SmartCam. Prototrak reads in .0005 but most Cad programs draw in .0001 or less, so I believe there is an overlap conflicy between how a Cad program is converted to how the 3 axis reads it. Hence tweaking numbers. I had a simple program on time profiling in "Z". 3 block. A straight angled line uo to a radius and back down to a straight angled line. Then it was looped with 999 repeats. Simple, simple, simple. Halfway thru the program it decided instead of running a clockwise arc, that it would run a full counterclockwise circle. Hell of a crash. I talked to Southwestern and they informed me that it had too many blocks in it, yet it will loop 999 times They put the same program into their machine and it would work. The next year they discontinued the QuickCell because of too many issues. Southwwestern really did not help at all with programming issues and after talking to them I kind of got the impression that some of their programmers were not the sharpest knife in the drawer. But enough for my rant. As far as the MX2, I have never had a problem with any size of program with it, and it will loop just fine either by manually programming or programming from a Cad program.
    Sep 2006
    33
    Has anyone got a copyof the Prototrak MX3 programming, operating and care manual that they would sell or copy and sell the copy?
    I have the mx2 manual but have the mx3 controller fitted on an ACER milling machine and cannot figure out some things on mx3
    Best Regards
    John O Regan
    Oct 2006
    48
    Smile MX3
    Hi John Have you had any luck finding manual? I run a TRAK-DPM bed mill with MX3, maybe I can help with your problem. Proto Trak does'nt have a very informative manual in regards to programing, just the basic terminology& some example programing and operation instructions.
    Nov 2005
    1468
    I run a Proto Trak AGE2 and have had no probelms with it at all. I know very little about conventional CNC being a Diamond Machinst by trade, but I went from knowing zero about this machine to cutting metal in a day.
    I design in ACAD, export to Dolphin and CAM in that then transfer to the Proto Trak thingy.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Sep 2006
    33
    Hi Gary, and Every One
    I hope I can explain my problems without getting everyone including myself confused.!!
    I am trying to make the valve rocker mounting pillars for a mid 1920's Blackburne engine, (I am going to try and attach some pictures as well).
    I am programming directly with the prototrak soft keys.
    I selected, prog, frame then arc, X and Y begin, Z rapid, Z begin,
    X,Y and Z end. all straight forward,
    Then X and Y centers (of the arc).
    The MX2 manual says;
    "In ARC events when X and Y center are programmed incrementally,
    they are referenced from X End and Y End respecttively." ??????
    in my case the center is, X=0.0 ABS, Y=0.0 ABS.
    Then it looks for Z center, WHERE THE HELL IS THAT???
    When the next event is continue mill, a straight line tangental to the ARC, (NOT directly X or Y directions) I used the Maths Help to find the reference points for the tangent.
    (First of all it kept telling me that this ARC was not possible with the points given).
    If I want to mill the top surface of a block say 4X3 that is clamped proud in the vice,
    How do I ask MX3 to do this?
    The Mill option only has two reference points
    I tried asking it to do a pocket larger than the block, say 4 1/2 X 3 1/2
    and entered the tool data as 1.5in dia (slabmill), however it started moving in very small square patterns each getting slightly bigger!
    It seemed to be ignoring the inputted tool diamater??
    I wound up squaring the blocks using the power feed, All very time consuming!!!
    Thanks for reading through this and I hope you will be able to point me in the right direction!
    Best Regards
    John O Regan
    Attached Thumbnails Attached Thumbnails blackburne rocker drawing 2.jpg   Copy of DSCN2260.jpg
    Sep 2006
    33
    Here some pictures of the parts that I am replicating.
    The rocker pillar is threaded into the cylinder head and then fixed with the locknut.
    I do not have to make the rockers themselves as I have been promised a NOS pair,
    These are only two components in a seemingly never ending list of parts to make during the restoration of my 1925 Chater Lea "Super Sports"
    Another Question, What would be the best material to make the pivot spindles from?
    The new old rockers have needle bearings for the pivots.
    Regards
    John
    Attached Thumbnails Attached Thumbnails P3100055.jpg   P3100056.jpg   P3100058.jpg   P3100059.jpg
    Oct 2006
    48
    Hi John Are you makeing the part with the threaded stud on it? If so how are you going to do the stud? Oh by the way I have a MX3 programing operating& care manual I can send to you
    Sep 2006
    33
    Hi Gary,
    If you look at the photos again you will see that when I machined the blocks I used the DRO to find and drill the centers at at each end, I can now mount between centers in the lathe and turn down and thread the pillar. it is very unusual 1/2 in X 24tpi, then machine out the center portion where the Rocker fits.
    I will post some more pics when I get that far,
    If you send me a private email we can sort out the details of the manual
    [email protected]
    Regards
    John
    Sep 2006
    33
    HI Gary,
    I want to "THANK YOU" on CNC Zone for your time and effort of sending me the MX3 manual. Your costs will be in the post Tomorrow 3/3/08
    I will post some more pictures of the parts when they are finished, I had a message on Saturday that the rockers are on the way to me.
    Regards
    John
    Sep 2006
    33
    Thanks Gary
    The Manual arrived safely, I will try out some 3D practice pieces using wood as I try and get my head around how it works
    I have nearly finished the first pair of rocker pillars machining manually, but I will not be able to complete the second pair until I collect the cylinder head next month as there is an issue with the thread size on it
    Regards
    John
    Apr 2008
    6
    The Mastercam website has an MX3 post available for download, free. Just click on posts, then at the right side of the page "V9 educational archive".
    To mill a 4 x 3 block, just use the subroutine repeat function. For example, mill across the upper portion of the part, then repeat with Y minus something less than the cutter diameter.
    Sep 2006
    33
    Unhappy
    Thanks for that leftcoastlefty,
    I have had not had much time to study the MX3 manual sent by Gary yet.
    earning a living gets in the way of home workshop time!!!
    My next parts to make are in the drawing attached, I hav'nt decided yet whether to machine them or to make patterns and get them cast
    All ideas and suggestions welcome
    Regards
    John O Regan
    Oct 2009
    Trak FHM5
    Kevin, my company is new to the machining world and we are in the market to purchase a 3 axis cnc bed mill. We are currently looking at the TRAK FHM5 w/h the Proto TRAK SMX CNC controller. Do you know anything about this machine and if not what would you recommend to purchase? Thanks, Dave
    Nov 2009
    Hey!!!!!!
    Hey I cannot figure out how to start a new thread, this website is either terribly laid out or I am impatient. Anyway, a machine shop in my school recently aquired a Chevalier milling machine with a Proto Trak M2 Digital readout and axis-controller. I was wondering where I could find a manual for this readout, just a general user's guide so we could understand how to work it. Thanks!
    Feb 2008
    51
    The proto trac software is pretty easy to use just try different events and try to be postive, its a lot easyier than putting and taking off a rotory table try doing some small programs and using the trail run and show path i have been using them for since the early 90,s
    Sep 2006
    33
    Hi
    You should be able to get the manuals from the manufacturers,
    http://www.southwesternindustries.com/swi/
    There are lots of different versions of the prototrak systems
    Regards
    John
    Aug 2007
    Post TRAK A.G.E. 2
    I am looking for a AGEOL – TRAK A.G.E. 2 program manual if some one can help Thanks.
  1. PROTO-TRAK
    By Gary55Ford in forum Fanuc
    Last Post: 01-26-2008, 01:47 AM
  2. Proto Trak?
    By Garage Shop in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2007, 05:38 PM
  3. BP Proto trak plus questions
    By Bruce Griffing in forum Bridgeport / Hardinge Mills
    Last Post: 01-08-2007, 06:12 AM
  4. RFQ 2 Op CNC Milling (Proto)
    By Spike_TDI in forum Employment Opportunity
    Last Post: 04-28-2005, 12:36 AM
