I am adding Renishaw probing to two Makino A71's with Fanuc 18i control. For probing it says that Custom Macro B and high speed skip are needed. Do I need software for this or is this a parameter change. please help.
The macro B is just a software option. High speed skip is a hardware/software option. I don not know about the A71's, but a FEW manufacturers put the hardware on all the machines regardless of the options ordered.
Bottom line, I'm pretty sure you need to talk to your dealer to get it to work.
At the very least you need 1 machine with it installed and working. (if you have more than one)
cancel
So I take it that this option is not something that can be turned on with parameters as is the case for older Fanuc controls
The A71 is not that "old" and neither is your control. However, on a Makino, its possible it may already be installed. Macro B should already be active with the Pro3 control and for the High Speed skip, you may already have the card installed. It's just a matter of someone coming in and making it active to the control. I know for sure the low speed skip should be running. Do you have the tool eye option on the machine? (That's the tool length measure unit). If so, you already have a skip card installed.
It's just a part..... cutter still goes round and round....
High Speed Skip 9936.4
Custom Macro B 9933.7
Additinal Varibles 9937.4
I am pretty sure you can get the Macro B abd theb daitinal Varibles But the Skip function might need a hardware upgrade.
Just make sure you have a back up of all your machine system parrameters befroe you start messing with the option parrameters
Bluesman
Bluesman,
is additional variables 9937.4 the same on a 18M model C control?
Once I change these parameters how can I tell if they are activated. Is there a G code
thank you dpuch, works great!!!
thanks, I was trying to find out on the High Speed skip when I turn on the parameter if the G31 would let me know if the proper hardware was installed.
Yes, you would need software to run measurements. The high speed skip input is on the back of the control screen(lcd), is the Ja40 Honda connector. If it's not enabled (View input F0122 on diagnosis) use the low speed skip.
Hope i've been helpfull
How do you know all the option parameters?
Recently, I got Dynamic Graphic feature activated on my 0i Mate TC, and Fanuc charged a hefty amount for this! They only changed an option parameter (9000 series) which took just one minute!
They told me that, on newer control versions, such things cannot be done using option parameters. Encripted files come for every control model and every serial number.
hello all
This question I had ask the bj-fanuc co,ltd ,they told me that, the newer control ,if you change a card of the nc ,you must need a new Encripted file. It only made by the fanuc!
Otherwise the nc only can run 720 hours.
N09000 P 00000000
N09001 P 0
N09002 P 0
N09003 P 0
N09010 P 00000000
N09011 P 00000000
N09900 P 5
N09901 P 0
N09902 P 0
N09920 P 01011010
N09921 P 11100010
N09922 P 00000100
N09923 P 10001100
N09924 P 00111111
N09925 P 01100000
N09926 P 01110000
N09927 P 01011010
N09928 P 10100000
N09929 P 01101111
N09930 P 00110000
N09931 P 01100110
N09932 P 10010100
N09933 P 10000000
N09934 P 01010110
N09935 P 00100000
N09936 P 10100101
N09937 P 00101111
N09938 P 00000000
N09939 P 00000000
N09940 P 10000100
N09941 P 00000001
N09942 P 00000001
N09943 P 00011000
N09944 P 10000000
N09945 P 00000000
N09946 P 00000100
N09947 P 00000000
N09948 P 00000000
N09949 P 00000000
N09950 P 00000000
N09951 P 00000000
N09952 P 00000001
N09953 P 10000000
N09954 P 00000000
N09955 P 00000000
N09956 P 00000000
N09957 P 00000000
N09958 P 00000000
N09959 P 00000000
N09960 P 00000000
N09961 P 00000000
N09962 P 00000010
N09963 P 00000000
N09964 P 00001000
N09965 P 00000010
N09966 P 00000000
N09967 P 00000000
N09968 P 00000000
N09969 P 00000000
N09970 P 00001000
N09971 P 00000001
N09972 P 00000000
N09973 P 00000000
N09974 P 00000000
N09975 P 00000000
N09976 P 10000001
N09977 P 00000000
N09978 P 00000000
N09979 P 00000000
N09980 P 00000000
N09981 P 00000000
N09982 P 00000000
N09983 P 00000000
N09984 P 00000000
N09985 P 00000000
N09986 P 00000000
N09987 P 00000000
N09988 P 00000000
N09989 P 00000000
N09990 P 00000000
N09991 P 00000000
N09992 P 00000000
N09993 P 00000000
N09994 P 00000000
N09995 P 00000000
N09996 P 00000000
N09997 P 00000000
N09998 P 00000000
Take care with any parameters mods!!!
dear moowod
it there your parameter upload from the machine ?
Fanuc co. add a funtion to the control that is use a "cnc opset.txt" file.
The file's content most like this:
N99000P0P4P6P8
N99001P39715P51747P61796P39414
N99002P45483P65361P25979P19780
N99003P201P34475P64374P28275
N99004P28356P60405P25531P44021
N99005P55747P27383P58848P27491
N99006P24238P356P55551P61729
N99999P0P4P5P6
It only use for Serial NO :EO86B3174
Open the AICC funtion.
of course ,if you known how to write this file.
you also could open a funtion for a control.
