sorry i was a sleep!!, wincnc has a start from line # feature i have had to use it, i'll get to a computer that hads win cnc and we'll get to it, send cut to the bone a pm and tell him what happened! jim
go to file
then restart command.
what type of support did shop sabre provide, also wincnc will help jim
I did the File>restart> located my file> saw what line it stopped on>hit ok and them the start in win cnc and nothing.
the one other time I got it to work I stopped a job 3 times.
I did the above procedure and hit ok then start. the cnc fired up to the RPM set and moves to where it will start. it then said something like Ready to start hit ENTER> I hit enter and away it went. so I have done it before but on this job it would not it just kept saying ERROR: BOUNDRY EXCEEDED and I had to run it from the beginning.
No SS support at 9 PM plus I think I pissed them off when I told them some stuff about their machine and the delivery date.
I can't complain about the accuracy though. I was able to do this, I don't know if this is special or not a big deal but I though it was pretty cool that I was able to do this.
the pictures below is (2) 17" x 50" 1/4" acrilic clear sheets. I used 3M 94 CA contact spray used for counter tops and stuck the two paper covered sheets together, making it .478" thick, them I took off the bottom layer in a spot to measure. then it measures .470" so then I told the cnc to Z Zero on top and cut .472" deep and the result is I cut through the material and am able to not cut throught the .008" thick paper backing.
I said I don't know if this is anything new to anyone but I thought it was pretty cool plus it helps hold the parts together and did not cut into my top at all.
Oh the way I held the whole thing to the table was that 2 sided Crepe tape I was talking about. Worked great.
I can see if I had a vacume table that this trick of not cutting throught the paper would keep the vacume suction up also. later.
if any one else knows what I did wrong that it would not let me restart du to a ERROR: BOUNDRY EXCEEDED let me know. thanks
tool I broke last night at line 30,232 or something and when I wanted to do the restart and was unable to.
Bit tempeture was 85 degress when it snapped
that looks good, got another sign job, .30 per inch sign foam and 100.00 per square ft. 3d
what was this plexi used for ??
people are using two fein vacuums for table with great success bought two on friday and will let you know jim
It is a local place called Custom Plastics.
he is a shop that makes all kinds of stuff with plastics.
shapes, plaques, holders, panels, boxes ect. all made of acrilic plastics.
if you have a shop like this in your area you should check with them. this job was 4 16x23" panels with 15Wx10H 1 3/16" holes with 5/16" spacing. just cut the holes and no clean up just give the sheet back and he does with it what he does. the other job was some odd end shapes.
my problem was I went back to him with a bid to do the first job of 60 parts for $180 he told me he gets it from somewhere else for $60
the second job he had was 4 of those 16x23 sheets with 150 holes. Quotes $120 and he said he would pay $20 ea so $80
My bid $ 300
what he would pay $140
Hours to complete with design 4Hr
Broke $35 bit
$105 profit
$25Hr made shops costs $32 hr to run I lost $28 to do this work for him. Isn't business Great!!!
CNC Camaster Girl
ben of bensmillwork found this and the detail is incredible
http://www.3dmodelclub.com/index.php...hk=1&Itemid=93
in addition to our regen blower and man what a difference the only pull 7.5hg
+/- but 2 feins and the regen are at 700cfms doing the job video later
break in of new spindles
http://pdscolombo.com/pdf/Spindle%20...ure%207-07.pdf
and care
http://pdscolombo.com/pdf/PDS%20Spindle%20Care%2007.pdf
great site, i have ordered new fan blades and now they are to loud so i will switch to electric fans
http://pdscolombo.com/support.html
on thursday we got a visit from "paul" of charllotte nc he is looking for his next machine and i hope he will consider camaster as i am sooo hopeing he'll
join our growing group of support, i am so grateful he came not only to see an 8 year old machine with 1/2 stepper motors but because he was so helpful in teaching my guys some important basics of cnc software and operations,
the new machine we are getting from bill is sooo much further along with the atc and such but paul was able to give them a glimpse of what is comming our way
i do not have paul's permission to use his full name here but i do want to say thank you and hope he'll review my machine here jim
Sorry to but in here, but I can't find much info on these machines. I have been to their website and it isn't to informative. I ask for info and got a phone call from someone(sorry forgot his name) I ask him to send me some more info, specs etc. but haven't seen a thing in two weeks. He seemed to be more about Art Cam training than the machine it's self.
There isn't much here on this brand other than this thread. Seems strange, How many of these are out there? Their own forum is basically vacant.
I am going to purchase a cnc router within the next 60-90 days I would like a 4th axis, or at least one that can be installed later.
I make mostly custom furniture now no cabinets, and would like to be able to also do carved mantels, newell(?sp) post, corbels etc.
Are these machines made in the USA? They look like the Chinese machines.
Should I just scratch these guys off the list?
Can someone enlighten me?
Scott
and i speak to bill glenn every few days there are quite a few machines out there that bill has built and i speak with some of them also, yes bill did sell the chinese machines and they are still are on his site, if you want one they are available from other companies in the us. they are widely discussed on this forum under excitech. i believe you spoke to a salesman (the artcam ) i would call again and ask for joey or bill they can help you if you wish you can pm me and i'll get you in touch
i can say i like my machine and i have ordered another with the lathe, spent most of tonight on the software there are several to choose from, yes i also have found it is hard to get a lot of support on a comercial forum but bill, josh, joey and the other camaster owners i keep up with have been very helpful there are machines in wilmington, camden sc, columbia sc several in fla, california and georgia as well that i know of
scott what part of the country are you in, i would say that camaster is not all things to all people, i like the fact that they are a small company and build two to four machines a month. i have been in woodwork for twenty years and am grateful for these fellows they certanly have made the transformation to cnc a lot less difficult than i expected.
and i will confess i post as i hope to build more support among this size of machine as i hope to build more of my business around cnc
any way thanks for asking
jim mcgrew
www.mcgrewwoodwork.com
this little switch cover was requested by our local hilton hotel after they saw the logo in vcarvepro the want all kinds of goodies,, the cabinets in the sweet shop were done with cabinetpartspro, ryan of cpp has a vew version coming soon and has let me play with it. he is making really good headway with it but as you can see it (cpp) is a very usable program as it is. i cut the wine racks with vcarvepro as well
scott thanks for contacting me i hope my info was what you were looking for jim
so i got to build her a new one with vcarve jim
it's worth the ride out here in the mountains of georgia just for the scenery!!
craig is here to pick up a 4x8 w atc and a 4x8 is being finished at the same time, the blue machine is being built for a fellow who will cut deep foam (high z) we will spend the day here in training.
oh an the machine upside down is mine!!!!!
cabnet636,
Very nice work!
Free DXF - vectorink.com
thank you!!
jim
kieth g godwin cabinetworks
various works in play!!
