I created one program making two cuts, a rectangle & a circle, using the CAM built-ins. Both run perfectly fine during the CAM simulation but after post processing to MACH 3, the circle hugely increases in size while the rectangle stays he same. I post processed again for MACH2 and loaded it into MACH3, with the same results. How can this be fixed? Seems to be fine in Dolphin Cam
Rick
