Originally Posted by
bilinghm
I am working on an idea to eliminate the inherent weakness of the X2 mill: the pivoting column feature. Although this might be considered of value by some, I think it diminishes the little mill’s utility. Both the X2 and the Taig have this useless feature.
Several people have created good fixes that strengthen and stabilize the pivot. I like the use of a bracket or angle plate affixed to the rear of the column providing better support and rigidity. Turnbuckles would also do a good job.
However, I am considering something different. I am thinking of building a wooden work station/table with a tall “back splash” that is built with great strength and rigidity. I would then add a sheet metal flange to the rear of the column, and bolt the column to the table’s back splash. This should make it column very stable, make tramming a cinch, and resist twisting and deflection.
Has anyone tried this?
Bill
