I am new to machining so bear with me...So far I have most of the operations figured out in Mastercam. Tapping, face milling, contouring, etc. I would like to know more about machining and removing the larger areas of stock around the part.
What programming techiniques do I use to do this? I would like to remove the stock in each corner and move to the next. Then do a contour of the part. Is this the right way to go about machining this part? If so, then how do I do this in mastercam?
I am clamping the part in a vise and flipping for the 2nd op.
Stock: 4.625" x 3" x 1"
Part: 4.5" x 2.98" x .875"
