586,961 active members*
2,893 visitors online*
    Jan 2008
    5
    fanuc 6m has system error 402
    When I turn on the control the CRT reads system error 402. I can not change to any other screens i do not think it is on the alarm screen. Was running find when I shut it off.
    Sep 2005
    767
    There is no alarm 402 that I can find on the 6M. Could that be alarm 602 or 902 ?
    Jan 2008
    5
    It is a "system error" 402
    Sep 2005
    767
    Found it. The 402 alarm is a 4th axis overload alarm. Do you have a 4th axis? If not, then the option parameter for the 4th axis somehow got turned on, so now it's sensing an overload for a servo that's not there.
    If you have a 4th axis, push the little RESET button on the back of the servo. Also, check the 4th axis cables to see that they're all connected properly.
    Jan 2008
    5
    It is wired for a 4th axis but I have never use the 4th axis.
    Jan 2008
    5
    It is wired for a 4th axis but I have never used the 4th axis.
  1. 904 system error on 6M
    By kstocklin in forum Fanuc
    Last Post: 05-19-2021, 06:57 PM
  2. Replies: 2
    Last Post: 06-08-2007, 05:42 AM
  3. Fanuc 15 M Ram Parity Error(system Lable Lost)
    By SBAGHAEI in forum Servo Motors / Drives
    Last Post: 06-07-2007, 10:40 PM
  4. 6M System Error
    By Sailor in forum Fanuc
    Last Post: 06-01-2007, 11:56 AM
  5. Fanuc 6 system error 908
    By hidivsultan in forum Fanuc
    Last Post: 06-23-2006, 02:43 PM
