586,911 active members*
3,899 visitors online*
    Question Mach3 R3.00 Mill 4 axis Foam cutter setup
    Hi Guy's,
    I am having trouble getting my 4th (A) axis to travel the correct distance. eg I do an x10 y10 z10 a10 and the first three go 10mm and the A axis goes about 10 inches.
    All steppers are the same and have the same all the parameters in the motor tuning. I have tried G50 to scale all the same no difference. The XYZ all have scale 1 while the 4th has radius correction on, is this a problem? I have tried setting both G21 and/or G20 but the 4 axis travels further and the command.
    Any ideas?
    Andy
    May 2006
    179
    Increase steps per rev. in motor tuning
  1. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  2. MS Excel 4 Axis CNC Foam Cutter Experiment
    By arman in forum CNC Wire Foam Cutter Machines
    Last Post: 10-25-2006, 09:04 AM
  3. Featurecam Lathe Setup X axis MAch3
    By whiteriver in forum FeatureCAM CAD/CAM
    Last Post: 02-21-2006, 12:04 AM
  4. My first CNC! soon to be foam cutter
    By nikolatesla20 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-06-2005, 07:48 PM
  5. Foam cutter
    By paulried in forum CNC Wire Foam Cutter Machines
    Last Post: 10-30-2003, 10:58 PM
