A friend just gave me a Homier 7x12 lathe with extra chucks, tools, holders, etc.
And I've used it already to make several small fixes out of wood & plastic.
Is there a small milling attachment made a lathe of this size?
HW
HW
Try this link:
http://www.littlemachineshop.com/pro...681&category=1
Walking is highly over-rated
I saw one similar to that on http://www.lathemaster.com
HW
Pick up a cheap angle plate and mount your compound to it - you can then use the lathe to machine a vise mounted the compound
http://www.use-enco.com/CGI/INSRIT?P...PMAKA=418-4315
Aaron
Thanks for the angle link.
Hey, that's a good idea. I have an extra compound. I could mount that to the vertical side of the angle as the z axis. And if I mounted a small machinists vice to the compound as a work holder? I'd have a simple milling attachment.
I can use the picture on "littlemachineshop" as a guide.
HW
A block of steel would work as an angle plate if you have the right size.
I looked into doing this but found the X1 micro mill on sale for ~$230. Now that the X1 is pushing $300, the X2 from Cummins ($399) is a better deal on a mill.
Aaron
Have no steel block, but that angle is cheap and I can work with that.
Thanks again for your help & ideas.
Herb
