586,740 active members*
2,500 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Determining the master PCB on 10T
Results 1 to 8 of 8
    Aug 2007
    793
    Does anybody have the information about types of master PCB's on 10T? For example, there is A16B-1010-0041/04A on my control and I want to replace it. I've found A16B-1010-0040/04C on the internet. But there are some differences (saw the foto): optical plugs are absented and there are 3 processors instead of 2 on my PCB. If I replace the plugs, take out processor and replace ROMs from my PCB, will it operate?
    Aug 2004
    218
    I would replace with the same part #, this will ensure proper operation.
    Are you using the optical plugs ?
    Sep 2007
    371
    You can use 0040 replacing 0041 with no problem, you just have to fit the board with the jumpers and add the IC's in your original board.
    GP.
    Aug 2007
    793
    Quote Originally Posted by cncdiag View Post
    Plugs are used for connection with interface module IF01A and with CRT unit.
    Regards
    Aug 2007
    793
    Quote Originally Posted by GPena View Post
    GP.
    Are all the settings explained in manual?
    Regards
    If you are using the optical plugs on your 0041 board. The 0040 board is not interchangeable because it does not have the optical plugs.
    Aug 2007
    793
    I want take the plugs out from 0041 and set them on the 0040. Are there any special ICs wich provide the optical interface? If yes, and I transpose them, will the system operate?
  1. Determining Cast Zinc from Aluminum
    By lwhiway in forum MetalWork Discussion
    Last Post: 05-06-2018, 11:59 AM
  2. HELP! determining brushes for DC Motor
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 06-04-2007, 06:45 PM
  3. Determining aluminum alloy type
    By bdrmachine in forum MetalWork Discussion
    Last Post: 12-13-2006, 03:22 AM
  4. Help determining correct power resistor
    By mvaughn in forum CNC Machine Related Electronics
    Last Post: 04-16-2004, 09:54 PM
  5. Determining VA load
    By Swede in forum CNC Machine Related Electronics
    Last Post: 04-10-2004, 10:00 PM
