Hello Team
I joined this Board to help me in sourcing my first CNC plasma cutter. I will be doing "high mix & very low volume" production for my HOBBY. In the Engineering world this would be a prototype support tool. I plan on cutting 1/2" or less mild steel 99.99% of the time. Approximately 4'x8' capacity and good vertical height control. I also prefer to use my PC via a standard interface (USB, serial, parallel, et alia) I'm looking for value which I define as "Quality divided by Cost" :-)
Although I'm formally trained as an Electrical Engineer, I want to plug this machine in and "use it" to cut parts (period). I want to drag and drop DXF from any number of software packages. I'm not hung up on "open vs. closed" architecture and all that STUFF. When I need a water pump for my Ford Expedition, I go and buy a Ford water pump and not an adapter to allow a small block Chevy water pump to bolt up to my Ford :-) I want plug and play with factory tech support.
Please help me to "get it right the first time". Thank you!
Warmest regards,
Mike Gibbons
Sugar Land, Texas
[email protected]
