586,149 active members*
3,587 visitors online*
Results 1 to 14 of 14
    Jan 2008
    6
    Question Backlash Compensation
    I have changed from using MPS2000 to Mach3 to run my Taig mill. The problem I am having is not knowing how to set the backlash compensation in Mach3. Can any one help me in the area?
    Oct 2005
    61
    Is this what your looking for.
    Mark
    Jan 2008
    6
    Smile
    Thanks, that worked.
    Jan 2008
    6
    Now that I have set the backlash, and have enabled it I have another question. Now that I am using the backlash, the feed rate downs to almost zero, when the the plot goes to X=0, or Y=0. Is theis normal when using the basklash?
    Solek
    Oct 2005
    61
    Solek,
    I'm not clear on what you mean
    "when the the plot goes to X=0, or Y=0"
    I don't think backlash compensation will slow it down.
    On the settings page do you have soft limits turned on?
    Mark
    http://microtools.ca
    Jan 2008
    6
    Mark
    To better define what is going on, it looks like as the direction changes from down to up, up to down, right to left, and left to right, it looks like the feed stops to adjust for the backlash.
    I do not know where the settings page is, so do not know if soft limits are on or off.
    Am a CNC beginner, got a lot to learn.
    Solek
    Jan 2008
    6
    Mark
    Found the setting page, and the soft limits is black, and does not change, when I click on it.
    Solek
    Oct 2005
    61
    Solek,
    I't sounds like the backlash is working corectly.
    but you will need to set up the amount of backlash compensation.
    I recomend you download the PDF manual from the artsoft web site and read that through.
    Mark.
    Oct 2006
    47
    Go to the General config menu in Mach 3 and set the "shuttle accel" setting to .01 This should basically eliminate the ramp up and down during backlash compensation.
    Frank
    May 2007
    715
    Just want to say thanks. I had this same problem. Now my machine rocks again. :rainfro:
    Now I need to get some helical couplers and I'll be a happy camper.
    Jan 2006
    461
    Hey toy, what else does the shuttle accel affect. Does this fix that weird little thing mach does when it compensates. I mean it slows and then picks back up? Thx
    Oct 2006
    47
    According to a post some time ago by (I believe) Art himself, it does not appear to impact any other settings. The value in the shuttle accel box sets the ramp up/down speed of the backlash compensation. Try it with a value of, say 2, then change to .01. You will see a dramatic difference in speed of backlash comp.
    Try searching using the key words "shuttle accel" for more info.
    Good luck,
    Frank
    Jan 2006
    461
    Thx Frank. I just did a search on backlash comp but ill try the shuttle search. Thx
    Oct 2006
    47
    You should also search the "Machsupport" and the Mach Yahoo group for more info if needed.
    Frank
  1. Backlash Compensation
    By cnccustom in forum Mach Mill
    Last Post: 11-22-2007, 02:33 AM
  2. Adjusting Backlash Compensation on a Cen. 6
    By TZ250 in forum Milltronics
    Last Post: 11-10-2007, 03:31 AM
  3. Backlash Compensation
    By utengineer04 in forum MetalWork Discussion
    Last Post: 04-26-2005, 05:42 PM
  4. Ballscrew or Backlash Compensation?
    By RXTurbo in forum Uncategorised MetalWorking Machines
    Last Post: 08-05-2004, 11:47 PM
