586,936 active members*
2,159 visitors online*
Thread: consumables
Results 1 to 7 of 7
    Jul 2007
    54
    consumables
    getting the assembly of my new dynatorch finished and getting ready to fire it up, my question is about consumables.
    whats everyone using my thickness will probably 14 to 12 gauge occasional 3/16
    i have a few tips for 80 amp..
    my powersource is a hypermax 1250, any settings would be great also
    thanks
    chris
    Aug 2004
    155
    Chris,
    I would highly suggest your contacting Hypertherm and let them recommend the size electrode and tip.
    Their tech support is 1st class and they enjoy talking to the end-user.
    Good luck with the 1250, you'll enjoy it!
    Tom
    Sep 2006
    113
    cstroke,
    I'm running a Powermax 1000 and use Hypertherms Finecut consumables for 11 gauge and thinner. I use 40 amp shielded nozzles for 1/8" to 5/16". For everything over 5/16" I use a 60 amp shielded nozzle. The back of your owners manual contains cutting charts. These charts include nozzle type, feedrate, current(amps), and arc voltage. They'll get you close. Tweak from there.
    Jcar,
    Jul 2006
    122
    cstroke,
    I am using fine cut tips as well, but can use them on up to 1/8" steel. I use the fine cuts for detail and on the larger parts(size wise less detail) I use 60 amp tips from 1/8" to 3/8" steel.
    There is a settings post on previous threads, you can print that out and they are pretty much spot on.
    Welcome to the DT family!!
    Ed-Ryno
    www.rynomobility.com
    Jul 2007
    54
    who are you guys buying consumables from and are you using hypertherms
    has anyone tried the thermacut( i think this is the right name)
    thanks in advance
    Jul 2007
    54
    i need a little help
    i need some ideas as what i should order..
    i'm just getting started and need to get some tips
    what should i be ordering, a starter kit??
    where should i be buying them from??
    fine tip consumables??
    and did anyone try the therma cut consumables?
    all i have is the 80 amps that came with the torch.
    part #s would be a big help
    thanks in advance
    chris
    Feb 2007
    62
    Don't know if this is the best place, but . . . here is where I ordered my fine-cut kit.
  1. Plasma consumables
    By jb_swampfox in forum Torchmate
    Last Post: 07-04-2007, 03:08 AM
  2. where to buy consumables
    By tuknrm in forum Waterjet General Topics
    Last Post: 02-14-2007, 08:04 PM
  3. Snap-On consumables
    By Captain Midnigh in forum Waterjet General Topics
    Last Post: 01-06-2007, 08:22 AM
  4. ThermaCut consumables
    By bossfrog in forum Waterjet General Topics
    Last Post: 12-12-2006, 02:26 AM
  5. Thermacut consumables
    By PlasmaGuy in forum Waterjet General Topics
    Last Post: 11-08-2006, 09:33 PM
