586,855 active members*
2,768 visitors online*
Results 1 to 5 of 5
    Jan 2006
    2985
    Triac Circuit design suggestions
    I recently bought an old rockwell porta band. It has adjustable speed but the circuit board no longer works and someone has bypassed it altogether. I would like to make a new unit so that I will have adjustable speed. Will a light dimmer do the trick to vary the voltage to the stator? I would stick in a triac but I'm not sure how to size the phase shifting resistor capacitor network I have heard about so that it fires symetrically.
    Thanks in Advance
    Matt
    Dec 2003
    24223
    You will find alot of data on the Manufacturers web sites like IR, Freescale, Allegro etc.
    You need to find out the max current load for the motor and size one accordingly, if the motor has a simple digital/pulse tach, there are series motor IC's than will give you stable speed control under load.
    Al.
    Albert E.
    Jan 2006
    2985
    Thanks Al
    This is an old unit 60's or 70's probably. I am looking for a rather primitive design using only a potentiometer, a triac and a couple passives, For the mentioned IC's I would need to provide dc voltage and supporting components, correct?
    Matt
    Dec 2003
    24223
    The basic Diac/Triac circuit is the simplest http://www.littelfuse.com/data/en/Ap...tes/AN1003.pdf
    The PDF is the Motorola used in appliances.
    Al.
    Attached Files Attached Files
    Albert E.
    Jan 2006
    2985
    Thats just what I was looking for.
    Thanks Again
    Matt
  1. Optocouplers for triggering SCR, not TRIAC
    By jc40 in forum CNC Machine Related Electronics
    Last Post: 11-21-2007, 08:52 PM
  2. Denford Triac VMC ? Any experience?
    By dfstrasser in forum Benchtop Machines
    Last Post: 06-18-2007, 09:15 AM
  3. Charge Pump DIY Info, Circuit, Design, PCB???
    By HayTay in forum CNC Machine Related Electronics
    Last Post: 07-09-2006, 03:47 PM
  4. Circuit-board, design software.
    By ynneb in forum CNC Machine Related Electronics
    Last Post: 08-02-2004, 10:40 PM
  5. Help w/ e-stop circuit design
    By owhite in forum CNC Machine Related Electronics
    Last Post: 03-07-2004, 03:16 PM
