587,043 active members*
2,992 visitors online*
Results 1 to 19 of 19
    Talking HAAS TM-1 Enclosure!!!
    I love the mill, love the operating system, but I could not stand how bad coolant went everywhere. All over the walls and the floor...It was a total mess. So, some good friends and I brainstormed. On the HAAS TM-1, the left side coolant catch panel was not long enough to clear the X-axis home position. So instead of mickey-mousing some extension setup, we decided to make a whole new panel. We fabricated the catch pan making it 3 inches longer than the standard panel, sanded all rough edges, and got some paint that matched perfectly and started paintin. That extra 3 inches of clearance made it possible to box in the X-axis without cutting a hole in the side like other home-built enclosures that I have seen.
    We cut out diamond plate to fit all sides and made sure everything was gonna line up. Then, again, we rounded off all sharp edges and put a couple bends here and there for appearance, strength, and clearance. Everything clears and so far all coolant is staying in the machine.
    A good friend constructed a front flip-door out of smoked plexiglass that would prevent heavy splashing from coolant hitting the center-bottom pathway. I put the door on hinges so I can clean out chips once they build up. And, last but not least, we cut out a final piece of diamond plate with an acute angle on top that slides in and out the front of the machine just as a "secondary block-out" incase the coolant really starts to flow.
    Below are a few pictures I snapped with a cell phone. I apologize for the poor quality of the pictures, but I'm pretty sure you can get an idea of what was done here! Hope this setup helps somebody out there.
    Attached Thumbnails Attached Thumbnails 123107_14401.jpg   123107_14403.jpg   123107_14411.jpg   123107_14421.jpg
    Enclosure
    Nice work. Looks very professional.
    Just got my new TM-1P today! Looking forward to having a nice machine.
    John
    Aug 2005
    235
    I also grew tired of cleaning up a never ending mess, Running for my life from flying crap and taking a bath in coolant. I decided to design and build and enclosure for the mill that would have plenty of room inside, be fully enclosed with a roof on it, have a setup to accept a flood coolant system and a chip auger. This is what I came up with. I still have not gotten to the auger yet but that will come when I have time to do it. The coolant system uses a waterfall pump from Home Depot and is wired into the control. The biggest issue that I ran into is that the controler was too far into the machine to build the cabinent this way so what I had to do was take off the controler, pull all the wires back to the cabinent, make a new support arm that was 14 inches longer than stock. I then had to pull the wires back out to the controler. a few of the simple ones had to have a section spliced onto them so they would reach. I used solder and shrink tube to ensure a good connection. Fortunatly, The video and data cables had plenty of length to spare. Now with this setup I put 2 to 5 gallons of collant a minute to the tool and run it like hell. I also stepped this machine up to 6000 rpm and 400 inches per minute on the rapids. All that I need to do now is get a tool changer for it. I did leave room for one in the future. I did totally scrap all the sheet metal the machine came with and started from scratch with fresh 14 gauge cold roll sheet and some various size bar and tube for the internal door tracks, support for stiffness and window tracks. I made aluminum placards for the front of the machine to replace the "TM-1" logo sticker that I no longer had.
    Attached Thumbnails Attached Thumbnails P1010021.jpg   P1010004.jpg   P1010011.jpg   P1010009.jpg
    Hi AMCTony,
    Another really nice enclosure.
    Boy! That coolant pump is a real gusher. Looks like a miniature fire hose. You must have a pretty large coolant tank to recover and recycle that amount of coolant. Nice job. You mentioned that you wired the coolant pump into the machine. Can you turn it on and off with the associated "M" codes? It so, that is really neat. You must have found a schematic or looked at a friends machine that had the factory coolant pump option. Either way you really did a nice job.
    John
    PS. I passed the spindle and feed speedup information that I saw here on the CNC Zone along to a friend of mine here in Florida and he was extremely happy to get that information as it added a new dimension to his TM-1 machine.
    Jul 2005
    340
    AMCTony, great job, I have the same problems ( coolant bath, short controll pedant, tool changer ) but I have the auger , recently I ask myself : change the machine or build covers and TC, but for the first one is no money and for the second I search for the sense, but You gived me a little chope can You post more photos of your new covers ? I really like them, thanks.
    Aug 2005
    235
    The Coolant is hooked into the regular system plug with M08 for on and M09 for off like usual. I had to order 2 wires from haas to jump from board to board in the machine. The P/N is the same on my TL-2 that has coolant so I just ordered these parts and used them on my TM-1. The pump is 115v and the plug is 230V so I just wired it to use 1 leg of the plug. I have been using it like this for around a year with no issues at all. The control just uses a solid state relay to switch a 230V Circuit so there should be no problem doing this. I built a coolant tank that holds 25 gallons and that seems to be enough to keep the thing well fed. I am posting some crude .dwg's of the cabinent. I never intended them to be used for anyone else but me so they are crude but they are 1 to 1 and dimensions can be easily placed on them.
    Attached Files Attached Files
    Aug 2005
    235
    Remember that the control support arm will need lengthened by around 14 inches. This requires complete removal of the controler and a little soldering. Not really a big deal but this may be uneasy for some people.
    Aug 2005
    235
    Here is a dwg for the name plates. You can use these to get printed stickers made or make fancy engraved aluminum plates like I did.
    Jul 2005
    340
    thanks !! that will be very helpfull , try to build or buy a programmable coolant ;-) it is very helpfull , how do you think to get a ATC ? build your own or buy from haas ?
    Feb 2007
    498
    amctony,i started to build enclosure also and im almost finished,how did you bump up your rapids and rpms?did you have to pay hass service to do this?
    thanks,steve
    Jul 2005
    340
    you need to change a few parameters only , you don`t need to call service , all this have been described allready at this forum, just search for it .
    Aug 2005
    235
    I would just buy the tool changer from Haas. With something like that I would want as few issues as possible.
    Apr 2008
    80
    I know this is an old thread. BUT I see AMCtony is still on the board, at least as of last Dec.
    I dig how you made this enclosure. What did you use for door glides? I am looking at making something very similar for my TM-1. Getting tired of cleaning up coolant.
    Thank you,
    Mark
    2005 Haas TM-1, 4th HRT160 - OneCNC XR4 Pro w/4th - Alibre Design Expert
    Metal-tech 4x4 - www.metaltech4x4.com
    Dec 2006
    75
    I was thinking of just adding on to the existing sheet metal that came with my machine, minus the stuff attached to the table obviously. Attached is a sketch of assembly that consists of a left and right side panel, a front panel and two door panels. In the assembly drawing the handles are shown on the doors as if they slide to the sides. I am considering making them counter weighted lift up doors instead. What do you think of this idea? See any flaws? Like was done by the author of this thread I would also have to extend the control arm out a bit to clear everything.
    Hercules
    2008 TM-1, 2008 TL-3, 2009 TL-1, 2010 VF-2YT
    Apr 2008
    80
    Quote Originally Posted by hercules View Post
    Looks good. I would put top corner gussets if not enclosing the top. The doors will create allot of movement just opening and closing. I too was wondering about using gas struts to neutralize (used up and down just dif. rates) a single center door that moves up and down. As long as the lip of the door is on the inside of the side panels, cant really tell there. Need that so coolant drips down to the lower pan. Side access also needs to be easy access to clean the non-auger machine out. I was thinking slide up panels like the VF's have for the sides then a flip down lower door below the main door to access under the bed for clean out.
    Mark
    Length of Vise Shafts
    One thing to keep in mind is to make the enclosure wide enough towards the front to make sure when the table is in the fully forward position that you can shut the doors without hitting the vise shafts. I have a HAAS 2007 TM-1P with the factory enclosure and I had to cut about .750 inch off the vise shafts to get the necessary clearance. Per a suggestion from a friend of mine I made some special wrenches for tightening the vise jaws instead of the OEM handles. They were combination box/open end wrenches. I cut the open end head off and inserted a piece of heavy duty heat shrink over the shank. I also straighten out the wrench so it would hang perfectly vertical. Then I bought some "O" Rings at the hardware store and slip them over the hex shafts to hold the box wrench in place. I am using the Kurt D688 Vises.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
    Dec 2006
    75
    Yeah good point. I agree I would need to add some gussets. I wasn't planning to close up the top. It doesn't seem like I need to do that. Not many chips or much coolant flies up that high now. Some chips do land on top of the umbrella tool changer if I cut hard and fast on aluminum though. Am I making a mistake not covering the top? I did intend for the side panel opening windows to be simple slide up sheets like the VF's use. Those do work quite well. Air assist cylinders is an interesting idea for the door if it slides up. I was thinking of counter weights and/or a cable and pulley or a cable and spring set up. In the end I'd like to make the door mechanism as simple and bullet proof as I can. And yes the flanges for the sheet metal would be bent inward towards the inside of the machine. On the bottom of the doors I planned to have that flange bent in and sloped down 10 or 20 degrees so coolant would drain off.
    A bottom door or hatch for clean out and verifying that I have enough front side clearance for vise handles are two things I hadn't thought through yet. Good tips to save me some heart ache there, thanks guys! Any other ideas or comments keep 'em coming, I appreciate the help.
    Hercules
    Aug 2010
    579
    Check out AMI, they sell an enclosure.
    Ken Foulks
    Dec 2008
    717
    Wow Ken, that is quite the enclosure...did they say "glass" front windows????!!!!!
    Looks good, though, Chalkboard. I remember having to get pretty creative catching all the coolant that ran out of our TL-1 and TL-2...
    Good thing we had a full sheetmetal shop and weld shop at my last shop....
    Tim
  1. What to use for an enclosure?
    By Tim Wiltse in forum Xylotex
    Last Post: 10-03-2008, 08:36 AM
  2. My new enclosure
    By David Da Costa in forum Commercial CNC Wood Routers
    Last Post: 10-28-2006, 06:03 PM
  3. New All In One Enclosure
    By mlaws1172 in forum CNC Machine Related Electronics
    Last Post: 10-21-2006, 01:26 AM
  4. My Enclosure please take a look.
    By Oldmanandhistoy in forum CNC Machine Related Electronics
    Last Post: 03-03-2006, 02:48 PM
  5. enclosure
    By strat in forum DIY CNC Router Table Machines
    Last Post: 02-28-2005, 06:12 PM
