587,045 active members*
3,041 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > USB to Parallel adapters?
Results 1 to 7 of 7
    Aug 2006
    281
    Anyone ever try one?
    I didn't realize until just now that my computer doesn't even have a parallel port. Of course I could another dedicated machine for a controller, but there's no denying that parallel ports days are numbered. I do like having all my software on a single laptop though.
    I saw this, for $14 seems like it would work great. Essentially making your CNC USB (without a Grex). I wonder if the Address would be the same (0x378) if it doesn't have a parallel on board...or how would you get the address?
    http://sewelldirect.com/usbtoparallel.asp
    May 2006
    94
    I'm guessing if $14 would replace $300 marriss would not have wasted his time.
    Aug 2006
    281
    Thanks Mr. unhelpful ;-)
    Grex does WAY more than just that offers a USB port...I just put that comment in because I knew I'd get a smarty who would say "just get a GREX." So much for that plan.
    Anyway, question is still pending.
    35538
    Quote Originally Posted by Chris64 View Post
    They won't work. You can get an ncPod or in a month or so the SmoothStepper should be available.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2005
    3634
    Gerry,
    Has anyone got NcPod up & running?
    If that board works, I can see it changing diy cnc, BIG time. The reason is they posted the source code on their site.
    I downloaded the SDK, & just tried the VB.NET sample, I got an error (couldn't find a DLL) I didn't really read any documentation, I just wanted to see some code!
    This looks like a great start!
    I would really like to get a lot more info on If others are working on NcPod projects, can you post any other related links you might have?
    I can see a lot of custom made (Open Source) cnc Controls being made in the future, that means a Free Control for everyone.
    My main concern is the max. stepper size it will run.
    Below is a screenshot of the opensource VB.NET control included in the NcPod SDK. It's a simple bare bones control, but a darn good place to start building on!
    Free DXF - vectorink.com
    Mar 2004
    761
    Fred Smith wanted me to write some code for the Nc-Pod, but he never got the prototype over to me to work on. Oh well....
    Wayne Hill
    35538
    Quote Originally Posted by Switcher View Post
    Gerry,
    A lot of guys are using it with Mach3 and the Mach3 plugin for it. Not sure if anyone is using it any other way. But for Mach3 use, the SmoothStepper supposedly offers far superior performance, as it was designed specifically for Mach3. For $155, it offers 4Mhz step rates and emulates 2 parallel ports, so should have enough I/O for most people.
    Gerry
  1. 1/4" Laminate Trimmer Collet Adapters?
    By vacpress in forum DIY CNC Router Table Machines
    Last Post: 02-26-2007, 06:09 AM
  2. (425 oz in) @ only 4.7V and 2.8A parallel?
    By Oldmanandhistoy in forum Stepper Motors / Drives
    Last Post: 02-17-2007, 09:05 PM
  3. CAT40/Haas Quick change lathe adapters
    By archer66 in forum Haas Mills
    Last Post: 09-06-2006, 09:23 PM
  4. Another Source for Collet Bushing Adapters
    By HayTay in forum DIY CNC Router Table Machines
    Last Post: 03-31-2006, 10:53 PM
  5. Micro drill adapters - alignment problems
    By buzzard in forum MetalWork Discussion
    Last Post: 02-01-2006, 02:58 AM
