586,594 active members*
2,851 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Very slow tool change on Tool Room Mill
    Dec 2006
    58
    Hey Everybody
    Where I work, we have a Haas Tool Room Mill. The boss has been on the machinist's butt to get faster with the machine. When it does a tool change, it beeps for 4 seconds and then goes thru the tool change. The question is, is there a parameter that can changed to stop the beeping and save the 4 precious seconds. Any help would be appreciated. Happy Holidays
    Sep 2006
    48
    Go to setting number 7 (parameter lock) and turn it off.
    Go to Parameter 601 (Tool Change Delay) and write down the value.
    Press the E-stop button and lower the value. It should be defaulted to a value of like 5000 (like five seconds).
    Cheers!
    Loose Nut
    Dec 2006
    58
    Thank you Loose Nut !!!!!!!!!!!!!! It worked great. Much faster now. Enjoy the Holidays
    Sep 2006
    48
    No problem Capt!!
    Be Safe.
    Loose Nut
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. Ajax Tool Room Mill
    By LUCKY13 in forum Centroid CNC Control Products
    Last Post: 03-14-2008, 05:03 AM
  3. Tool change
    By corydoras in forum CNC Wood Router Project Log
    Last Post: 11-25-2007, 04:45 PM
  4. Tool change
    By lilricky2 in forum BobCad-Cam
    Last Post: 06-03-2006, 07:00 PM
  5. tool change
    By Dwallace in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-24-2005, 07:17 PM
