586,115 active members*
3,476 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Router Bit or Endmill
Results 1 to 15 of 15
    Oct 2007
    6
    I have been using a router bit until now. I am planning to use an endmill to cut a pattern on FAGOR 5 axix cnc machine. I would like to know is there any technical difference between an endmill and a router bit?
    Thanks.
    May 2005
    1810
    The flutes of router bits are usually straight and produce no shear. End mills typically have helical flutes and will produce a smoother surface in most wood that I have cut, which is not all that much.
    If using a straight tool, I use end mills.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Sep 2005
    28
    Not necessarily. Most of the bits from woodworking stores seem to be the straight flute brazed carbide type, I have found that these do not work well in my cnc router.
    I have found that carbide 2 flute end mills work pretty well in wood when you get the feeds and speeds ironed out.
    If you really want the best to rip through wood then take a look here. All kinds of great stuff...
    https://www.onsrud.com/
    chad
    35538
    Spiral router bits have different geometry and bigger flutes than metal cutting endmills. I've never used endmills, but I believe that router bits should allow for much higher cutting speeds. Router bits are also a bit more expensive. Another supplier of high quality router bits is www.vortextool.com
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2006
    489
    Endmillls are designed for lower speeds with proper chip evacuation. If you use them in your router with speeds in the 10K+ range, they will just burn. End mills require a 'real' and consistent cut. Strait flute carbide router bits don't need a real cut and will still stay sharp. (this is my opinion)
    One of my workers asked recently how often I used to change my 1/2" carbide 2 flute cutter when I made stuff with a bosch router and templates. Got me thinking...'never' was my reply, one tool worked for more than a year, with excessive use. It's now in a glass shrouded case. Now I replace 1/4" endmills every 10 pieces. If I don't, the pieces aren't the right size. Some times up to 10 thou too small on internal cavities. One carbide 1/4" cutter I had lasted an incredible 60 pieces! I would pay big for tools like that! It's next to the 1/2" router bit.
    If you are using the endmills with cnc, you can increase your feed quite a bit, and it will also be very quiet. Keep in mind that the faster the feed, the higher the upward force to your table and clamps. Make sure they can handle the upward force without moving lateraly. Experiment first.
    In most cases, I would rather use an endmill over a router bit.
    Paul
    Jan 2007
    117
    Router vs Mill Bits
    I had a need to cut a 2" deep pocket in hardwood on my CNC router. Couldn't find a suitable router bit so I purchased a 4-flute solid carbide spiral mill bit (1/4").
    The geometry of the mill bit flutes didn't eject waste fast enough when cutting a path .2" deep/pass. The result was some chatter in the bit during the cut. The chatter was minimized by reducing the depth/pass to .1"
    This only happened on enclosed paths. There was no chatter on cuts where one side was open allowing better wast removal.
    May 2005
    1810
    Quote Originally Posted by Clockwork View Post
    ..so I purchased a 4-flute solid carbide spiral mill bit (1/4").
    I think you would be hapier with a two flute EM. What you have there is meant for finishing and does not have very deep flutes as you know. A 2 flute EM would do better for you.
    Scott
    Jan 2007
    117
    Scott
    Thanks for the insight. It makes sense now.
    Apr 2004
    5737
    The trouble we've been having with helical-flute endmills is that they tend to hook the wood and pull themselves out of the collet, with disastrous results for the piece we're working on. Carbide doesn't give the collet much to grip on, and high-speed tooling doesn't use the notch and set-screw system that the toolholders in mills can have. I've ordered some straight-flute cutters made specially to see if they work any better; I'll keep you posted...
    Andrew Werby
    www.computersculpture.com
    Nov 2007
    60
    Well, if i may add to this, we run only wood (except for when making fixtures) and we use 3 flute, up spiral router bits, in both solid wood and particle board etc... It really depends on what you're looking for in a cut. If you can, use a hogging or roughing bit for the first material removal operation. Be sure to leave 40 thou or so on the perimeter (x,y axis) and then use a straight flute bit to go back over and put a "finishing" pass on the part. A rougher with serrated flutes can FLY through alot of wood fast, very quietly, and with much less cutting force pulling on the part. Check out www.amanatool.com, they don't sell direct, but look through their CNC tooling stuff. Also, if you can use a bigger bit, the better off you'll be. Especially for roughing. You can rough it with a larger tool, then finish it with a smaller tool. Hope that gives you some new ideas to think of "outside" the normal thoughts
    Jun 2005
    180
    If you need clean edges on the top surface of your wood then use a down spiral wood router bit. This sends the chips down into the cutting channel and hence leaves a clean top edge with no breakout. An upcut spiral bit will through the chips up so feed rates can often go up but the top edge will feather. Upcut spirals require firm work holding as they try to lift the part (just like an endmill). Down cut spirals can cause compaction of the chips at the bottom of the cut which reduces performance. Get round this by creating an ofset of your part and then stepping in for a finish cut, you should get a very clean cut that way. The geometry of end mills and spiral wood router bits are different, but I do use carbide end mills occasionally for cutting wood without too much problem. Straight fluted wood bits are ok when new but a spiral bit is far superior as the cutting edge is constantly in contact with the part, and the shear cutting action eliminates tearing out and bruising on end grain.
    Nov 2007
    60
    All very good information for the guys Haydn. I didn't mention the up/down spiral tendencies.
    103
    I have been using end mills in place of router bits on some wood projects because of easier supply and 50% lower cost. The end mills don’t leave a finish that’s as nice and don’t last nearly as long. In addition, the end mills don’t seem to work as well on aluminum when used at router speeds (over 12,000 rpm).
    Jul 2014
    35
    Re: Router Bit or Endmill
    My 2 cents. My estimation is end mills are cheaper because there are tons of machine shops out there. They are highly used, so prices come down. I have a hard time rationalizing buying a more expensive router bit that just seems lower quality if I can do the same with an end mill. 2 flute. Granted, they are typically upcut so you won't get all the options. There are CNC machines out there that go plenty high RPM and end mills have higher SFM specs than they used to. For me, I calculate my SFM and Feed rate before cutting, so I'm not guessing.
    Jun 2013
    5
    Quote Originally Posted by CosmosK View Post
    My 2 cents. My estimation is end mills are cheaper because there are tons of machine shops out there. They are highly used, so prices come down. I have a hard time rationalizing buying a more expensive router bit that just seems lower quality if I can do the same with an end mill. 2 flute........
    An awful lot of router bits are made every year, and sold into both the consumer and commercial markets. So I doubt quantity is the reason for the price differential. Router bits, particularly the "0 flute" and 2 flute router bits like those offered by Onsrud, have a more open core than a 2, 3 or 4 flute end mill. That allows them to cut slots and plunge better than an end mill (in softer materials). With an end mill in aluminum, I often have to make multiple passes with a smaller endmill, or the cut width will be oversized. The router bit will plunge to full depth (if it's not more than 2/3 the cut length of the bit), and cut to a finished slot width within .005" of the tool diameter, as long as you have a way to clear the chips.
  1. Used endmill price?
    By Pete m. in forum MetalWork Discussion
    Last Post: 01-04-2013, 08:24 PM
  2. Want to buy 1/16 endmill .375 loc
    By elsocal in forum Want To Buy...Need help!
    Last Post: 12-16-2010, 11:13 AM
  3. Can I still use this endmill?
    By Kingjamez in forum Benchtop Machines
    Last Post: 11-07-2010, 01:02 PM
  4. Endmill to cut aluminum with high speed router?
    By LessPaul in forum DIY CNC Router Table Machines
    Last Post: 05-10-2010, 11:00 PM
