586,395 active members*
3,002 visitors online*
Results 1 to 7 of 7
    Dec 2007
    Multiple spindles on Mach 3 mill
    I am relatively familiar with setting up and running Mach 3 Mill on single spindled machine. Does anyone have any experience on setting up Mach 3 to run multiple spindles?
    I realize I can change my offset for the X and Y difference from the primary spindle, but what is the best way to turn the other spindles on or off?
    The machine I am considering for a retrofit has 3 router spindles. They all use the same variable frequency drive, so I need to select different ouputs for the motor contactors, but the speed control is the same for all of them.
    Any ideas would be greatly appreciated
    If there are three independent Z axis, Mach has a "swap axis" fuction. So while you may have them set up as Z, A, and B, You only need to use Z in your g-code. You just call the swap axis to switch between spindles. I don't know the exact syntax of the command, but it's something like swapaxis(1,4).
    You'll probably need some cutom macros and outputs to turn them on or off.
    Dec 2007
    This is a single z-axis machine with multiple spindles attached to it. A swap azis would not work, so it sounds like I will have to create macros for the other spindles.
    Is the macro programming pretty straight-forward on the Mach 3?
    Jan 2006
    2985
    I think you can use spare M functions for certain outputs. Setup something like this:
    M03 spindle 1 on/off
    M** spindle 2 on/off
    M** spindle 3 on/off
    Then add in the appropriate x y offsets in your g code and maybe the swap axis as Gerry had explained and you should be in business.
    Matt
    Dec 2007
    Thanks for the input keebler. That will probably do the trick.
    I have been going back and forth trying to decide if I want to use Mach3 for this CNC retrofit, or CamSoft. The Mach3 method will be a lot less expensive, but I don't want to run into a lot of downtime writing macros, etc.
    Jun 2012
    25
    Re: Multiple spindles on Mach 3 mill
    I saw your write up. Jomijen, did you figure something out for your multiple z axis? I was interested to see what you can up with. I have been contemplating putting my laser, cam scanner and spindle on one plate and being able to use the different ones when needed.
    Oct 2005
    1145
    There is another way. Create a master M3 macro that uses a Param call.
    M3 P1 would turn on and setup Spindle #1
    M3 P2 would turn on and setup Spindle #2
    M3 P3 would turn on and setup Spindle #3
    You could set up all the parameters such as the output signal to activate correct relay
    AND setup the XY offsets to align the spindle correctly.
    Then M5 would simple shut off all 3 outputs and remove any offsets so it reverts back to spindle #1
    Just a thought, (;-) TP
  1. How are you changing tools? Multiple spindles? ATC? Manual?
    By Smertrios in forum DIY CNC Router Table Machines
    Last Post: 10-28-2013, 05:50 PM
  2. Mounting multiple high speed spindles?
    By Wog in forum Tormach Personal CNC Mill
    Last Post: 09-25-2012, 09:49 PM
  3. odd question, multiple gantries and spindles
    By AndyL in forum Uncategorised CAM Discussion
    Last Post: 01-16-2012, 07:34 AM
  4. Rhinocam and multiple spindles and or multiple tables?
    By brett gallmeyer in forum Rhinocam
    Last Post: 02-23-2011, 08:30 PM
  5. Multiple Spindles (Routers)
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 04-26-2008, 06:37 AM
