Originally Posted by
Bluesman
No the programs will not overwrite the exsisiting, You have to either change them in the new file before you transfer baclk to the NC or delete the old programs. You can do a mass delete by EDIT O0001,O8999 DELETE this wipes out everything from program 1 to 8999 if that is what you are looking to take out.
Then to upload from the card go to EDIT hit the right soft key until you see CARD hit CARD then OPERATOR untill you see F-Read hit F-Read imput the file number on the card by 1 F-Set EXEC if you did it right you should see the umbers scroll.
I am sure this is it it is hard to write it down if you are not at the control
Bluesman
i would not advise deleteing the 8000 series programs, some times the machine builder uses them in the machine
If you can ENVISION it I can make it
