When i do a 3 axis finish with anything under .005 in the stock to leave section. I get a buch of rapid moves and messed up tool paths is their a fix for this?
have u registered the software?
yes
Why then u not talked to Surfcam staff directly?
cause i didnt update maintenence yet
No problem... the staff there is very co-operative ... if u have any trouble call them they will help u
wont i get charged for calling wothout a maintenence contract
hmmm...i dont think so... ur quiry is very simple...they will solve within minute
Jamesr, can you post a sample file with this problem?
Are you talking about Z-finish or other function ?
Give more detailes and we will help.
yes it is z-finish i zipped up the post so you can backplot to see the tool path also included part file
Just looked at your file and I’m not getting what you are, odd. When I do the Z level finish it works fine and I’m not seeing any difference in what I imputed from what you have imputed in the cutting parameters. Have you tried to reprogram it using all program defaults? I’ve seen Surfcam give strange results on occasion but have restarted Surfcam and the problems went away.
After some playing around this afternoon I managed to make it work somewhat. I’m not sure what’s going on but the operation that you created goes crazy in my system as if the walls are under cut, creating a lot of extra moves. It also took forever to regenerate. It shouldn’t matter but the surface normals (arrows) were flipped inside on some surfaces. I changed these to face outward on all the surfaces and it worked fine, only took a few seconds to generate. Like I said it shouldn’t matter when using Z finish but apparently it did on this model. I had to restart Surfcam once to make it behave properly after trying different scenarios (It kept ignoring the boundaries until I restarted). This is a good example of why shops are turning away from Surfcam. This program needs a major overhaul and Surfware is so slow to respond to any suggestions.
check "maximum feed between"
