586,096 active members*
3,807 visitors online*
    Dec 2007
    Mori Seiki SL 0H turret
    HI, We are operating a Mori Seiki SL 0H, purchased without an operators manual or for that matter, any paperwork at all. We have managed very well so far with just one exception. We have been unable to find the code to enable us to shortcut the turret movement, in other words, to move from station 2 to station 1 we have to do a full rotation of the turret.
    Is it possible to short cut and if so can anyone help?
    PS. This is my first shot at using a forum so please excuse any naveity.
    Bill Small
    Aug 2007
    31
    If your machine has the option it should be M17 M18
    Oct 2007
    74
    don't quote me, but I think that the SL-0 has the hydraulic turret motor, and if I am correct about that, then you are limited because the control uses BCD to track the turret position switches and limits you to one direction.
    Aug 2007
    31
    I have a 1980 Mori sl-3 with a fanuc 6, yes the turret is all hydraulic, however i can use m17 m18 on my T#### line to control direction
    Mar 2006
    370
    Bill
    I have a SL-00 from 1993 with a FANUC. My turret only turns one direction but I have never questioned it because it spins so fast it does not matter to me.
    However my manual states that the turret should turn what ever direction is the shortest rotation to the next tool. And it states that the M17, M18 can be used if parameter 561.4(K1.4) is flipped. It states the purpose is so you can use a tool that is too long to make the rotation and so must be kept from going all the way around.
    I plan to look at it more.
    Cheers
    SF
  1. Mori-Seiki SL-3H
    By B_Bueno in forum MetalWork Discussion
    Last Post: 12-20-2011, 04:00 PM
  2. Mori Seiki Sv-503
    By mr-seiki in forum Servo Motors / Drives
    Last Post: 06-04-2010, 02:52 AM
  3. mori seiki?
    By manuelc149 in forum Uncategorised MetalWorking Machines
    Last Post: 10-25-2007, 12:15 AM
  4. Mori Seiki SL-204
    By dcworld in forum Uncategorised MetalWorking Machines
    Last Post: 07-28-2007, 04:25 AM
