586,384 active members*
3,602 visitors online*
    Nov 2006
    21
    Looking for Help with Mach3 and LazyCAM
    Usining ver 2.42 of Mach3 on Vista Ultimate.
    I imported a gif file and traced it with TurboCAD. Converted it to a polyline, stripped all of the other layers and saved it as a .dxf. I can open it in LazyCAM, run a quick clean and set everyting up; export to gcode.
    Heres the problem...... When I open the file of gcode, only part of the project shows up. Sometimes more parts than others (same file.)
    Am I doing something wrong?
    Attached Files Attached Files
    Jan 2008
    Unhappy Mach LazyCam Partial File Load problem
    I am having the exact same issue, Im using ArtCam 9 pro to open a BMP
    then vectorize
    then create toolpath,
    then export DXF,
    Open DXF w/LAZY
    it shows it fine
    then open GCODE w/MACH
    BAM.....partial file either the left half or the right half......ive tried scaling, moving the origin....IM LOST
    SOMEONE HELP US!!!! :-(
    Do you have a registered version of mach3, or the demo? The demo will only show 500 lines in the toolpath display.
    Jan 2008
    partial job
    No, its full ver I can change the origin point and it will show either the left,middle,or right portion almost like the size or limits are wrong,but i verified the size as 7 x 2 inches...
  1. LazyCAM - Mach3 Scale
    By nadimhoque in forum OpenSource Software
    Last Post: 11-14-2007, 02:09 PM
  2. Need help with lazycam
    By jeffg in forum Mach Mill
    Last Post: 05-31-2007, 05:43 PM
  3. Lazycam
    By dan dimock in forum Mach Software (ArtSoft software)
    Last Post: 04-15-2007, 01:44 PM
  4. Help with LazyCam
    By randyf1965 in forum Mach Software (ArtSoft software)
    Last Post: 04-26-2006, 11:20 PM
  5. LazyCam
    Last Post: 04-18-2006, 04:29 PM
