587,035 active members*
3,273 visitors online*
    Sep 2005
    39
    Unhappy Haas startup error
    I was loading a program a few minutes ago, and the control froze during the transfer. This was a USB port transfer. I finally restarted the machine. Now, it won't start. Gets to where it says Haas on the screen, but it says "prog data error" on the lower left of the screen. It's a EC-400, about a year old.
    Anyone have any ideas? Any secret reset buttons or code combinations I am unaware of?
    Jul 2005
    12177
    I think you are out of luck. Big Mak may chime in here, he has a machine about that age which gave problems that needed a software upgrade to fix; I suspect that is what you will need. I have two machines that age and every morning I stroke my lucky rabbits foot...it has worked so far
    Jun 2006
    629
    Get the tech to upgrade your software, and this should go away.
    Hard start the machine, and see if you can get in, and select a different program, then atleast you can try to dump the program again and write over the corupt file.
    It sucks, but I think they can do the update in under an hour. It took them a few tries to get the software right, but I haven't seen any problems in I'd say 6 months now.
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Sep 2005
    39
    They will be out this afternoon or tomorrow morning. Told me over the phone they may have to reinstall the software. This is the first time it's happened. What's a hard start? Is that different than a normal cold start?
    Jun 2006
    629
    Shut off the control, and flip the switch at the back of the machine. Wait a minute, and start it up again. You have to find a way to get into the list programs, and select a program that is not corrupt.
    Sep 2005
    39
    Selway came out and performed the software upgrade. All is good again.
  1. HAAS VF1 Startup Problem
    By rkdygert in forum Haas Mills
    Last Post: 07-25-2007, 12:59 AM
  2. Error on Startup
    By JerryFlyGuy in forum Phase Converters
    Last Post: 06-28-2007, 03:22 AM
  3. V2XT startup fail error-1
    By photoron2 in forum Bridgeport / Hardinge Mills
    Last Post: 10-05-2006, 05:21 PM
  4. Haas HL-4 ERROR Codes
    By altcan in forum Haas Mills
    Last Post: 09-13-2005, 03:33 PM
  5. HAAS 123 error
    By marto74 in forum Haas Mills
    Last Post: 05-18-2005, 08:24 PM
