587,006 active members*
3,180 visitors online*
    Dec 2006
    22
    Gang tooling vs turret
    Sorry for the double post. I found a forum more appropriate for my question.
    I'm deciding on which CNC lathe to get.
    One under consideration is an Omniturn GT 75 (or Jr version), both of which are gang tooled.
    The other lathes I am looking at (mainly used) all have a tool turret for tool changes.
    Most of my stuff is less than 1" dia. by 5" long. I would like the capability to cut longer stuff as needed.
    I'm a newbie with CNC lathes. In the pictures, it looks like that I can only cut something a few inches long with a gang tooled machine. Am I wrong? Can you cut a part up to 9" long (Z axis movement on the Omni) with gang tooling and not run the part into the tool holder?
    Anyone have an opinion one way or the other for or against gang tooling vs a turret?
    992
    Depend on what your company doing if most of the part you have is small then gang tool is a perfect job for part smaller than 1.2" diameter and 5" long, and it will save you a lot of time in the long.
    The best way to learn is trial error.
  1. What About a Gang Lathe?
    By BobWarfield in forum Mini Lathe
    Last Post: 09-12-2008, 05:08 PM
  2. Gang tooling vs turret
    By baldysm in forum Uncategorised MetalWorking Machines
    Last Post: 12-03-2007, 11:47 PM
  3. Nikken TT35 Tooling for King Rich Turret
    By fabianlj in forum Bridgeport / Hardinge Mills
    Last Post: 05-23-2007, 01:58 PM
  4. Tool Shift for gang tooling
    By elaganis in forum Haas Mills
    Last Post: 03-09-2007, 10:48 PM
  5. Gang 2 controlers ?
    By onthemarc in forum Mach Software (ArtSoft software)
    Last Post: 12-06-2006, 11:31 AM
