586,359 active members*
3,586 visitors online*
Results 1 to 7 of 7
    Sep 2004
    149
    inkscape to G-code
    Here's an interesting link to a page showing how to use inkscape and a plugin to create g-code. It worked for me.
    http://wiki.linuxcnc.org/cgi-bin/emc...?InkscapeHowto
    Dan
    Jun 2005
    260
    It is cunning idea, though in larger projects, using segmenting curves to represent lines will slow down Inkscape.
    [I used Inkscape to design a guitar. It's a fine program, but for a fairly large project I noticed some slowdowns on a reasonable machine.]
    Converting the curves to lines will mean more file management: one as a source, another to be CAM'ed.
    Pushing the idea further. allowing the plugin to G-code curves might be a good thing for people who do a lot of 2D sheet metal work.
    Mar 2010
    4
    G-code
    I downloaded Inkscape. I wish to use the plugin "G-code"
    Cannot figure out how to get the plugin to load into proper area.
    I am on a Mac and know my way around. Extension does not show in extensions folder so I am assuming I didn't do something right
    I normally hand code my programs, just thought this combination of programs might save my 76 year old gray matter.
    May 2005
    1662
    I know Mac's like I know rocket surgery but.....
    Quote Originally Posted by donferg View Post
    The .inx and .py files must be extracted from the download and placed in the same folder as the other extension files. On my Linux machine that's usr/share/inkscape/extensions. The .py file may need permission to execute and the script may not run on all versions of python.
    That wiki page has a few gcode-from-inkscape extensions. One of them (provided by Glenn Harris?) is possibly corrupt. The one listed at the top (gcode_tools) is the newest, and in my opinion the best. The developer doesn't list Mac as one of the systems it runs on. If it does run on Mac he'd probably be interested in knowing.
    Sep 2008
    229
    Right-Click on Inkscape.app, select "View package contents" and navigate to Resources:Extensions. Drop the files there.
    The gcode extensions then show up in the extensions menu.
    That probably isn't the correct way, but it works.
    Jun 2003
    232
    Is there a Windows version of this program?
    Thanks.
    May 2005
    1662
    Works on Windows
    The conversation has moved
    http://www.cnczone.com/forums/showthread.php?t=99063
    download can be found here
    http://www.cnc-club.ru/forum/viewtop...&t=35&start=20
    One of the developers answers questions at either of those locations.
    The old (Hugomatic) extensions also work with windows afaik.
  1. how to create code with inkscape
    By dertsap in forum Uncategorised CAM Discussion
    Last Post: 12-28-2010, 10:08 PM
  2. Please Help Me With INKSCAPE
    By diarmaid in forum Uncategorised CAM Discussion
    Last Post: 10-29-2010, 11:47 AM
  3. G-code for beginners - want to learn G-code
    By FPV_GTp in forum G-Code Programing
    Last Post: 11-18-2008, 06:25 AM
  4. inkscape drawing for lathe
    By ChinaMan in forum Uncategorised CAM Discussion
    Last Post: 11-17-2007, 02:05 AM
