Originally Posted by
Richards
Use a multimeter to measure the resistance between the various wires. Since you have a six-wire motor, three of the wires will go to one coil and three of the wires will go to the other coil. For instance, on an M092-FD09 motor that I have, one coil has Red, Black and White/Red wires. The other coil has Green, White, White/Green wires. The Red and White/Red wires on one coil and the Green and White/Green wires on the other coil are used with Bipolar Series wiring. Either the Red and Black or the Black and White/Red wires on one coil and either the Green and White or the White and White/Green wires on the other coil are used when the motor is wired half-coil. Because the motor only has six leads, it cannot be wired Bipolar Parallel. Bipolar Parallel wiring requires eight lead motors.
