587,036 active members*
2,831 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Loading Program trough RS232
    Jul 2020
    31
    Hi All
    Acramatic 2100 I ran into an issue while loading programs.
    When I start the machine I have no problems sending program to machine via RS232. After about 20 minutes. I get an error (Not able to read file) Not sure what is going on
    Also I loose my touch screen about the same time. I had the KTI 2 Board replaced.
    Is there a connection between the two since the both connect to the workstation . Tried a different workstation same result.
    Could it possibly be a cable
    Thanks Joe
    Re: Loading Program trough RS232
    The problem might come from the CNC or PC or Cable connection.
    Since the touch screen also failed, then most possibly the problem from the the CNC side.
  1. Replies: 0
    Last Post: 11-06-2022, 10:33 PM
  2. Acramatic 850 RS232/ program loading help!!
    By Bruns-Garage1 in forum Cincinnati CNC
    Last Post: 11-01-2019, 01:19 AM
  3. Loading NC program
    By data-matique in forum HURCO
    Last Post: 06-17-2018, 03:43 AM
  4. LOADING PROGRAM
    By SELECT in forum SIEMENS -> GENERAL
    Last Post: 07-08-2010, 05:48 PM
  5. loading program
    By SELECT in forum Haas Mills
    Last Post: 08-14-2008, 12:31 PM
